Question about Samsung Blue- Ray Disc Player With Bonus Hdmi Cable Bdd5250c, Wi-fi Ready;
Bd-e5400 power light blinks 3 times but doesn't power up
How do I connect my Samsung BD-E5400 blu ray player to tv and watch netflix with a wired internet connection?
From the modem to the blu-ray use an ETHERNET cable. From the blu-ray to TV use an HDMI cable. They only fit in the right terminals.
May 03, 2014 | Samsung BD-E5400 - Blu-ray disc player
Installing blu-ray disc player w/ built in wifi. my router is set with WPS security. blu ray won't connect because cannot support theTKIP security type in 802.11n mode . How do I change the se
Try different security types. WEP, WPA2-PSK . Setup the device, you didn't post the Make, Model of device, to WPA2-PSK if you need to update the firmware go to the manufacturer's website and install the latest firmware version. If you need to update the firmware in the Samsung take a look here: http://www.samsung.com/us/support/owners/product/BD-E5400/ZA
Apr 06, 2013 | Computers & Internet
How do i unlock the region on my samsung bd-e5400 region free?
1. Ensure that there is no disk in the tray.
2. Switch the player off and then back on. This is necessary to clean-boot the
firmware.
3. Wait until the main menu page appears and the player stops doing
anything.
4. Press the eject button to open the tray. (The button is between the "Power"
and "TV Power" buttons at the top of the controller.)
5. Press the eject button to close the tray.
6. Wait while the player searches for a disk.
7. As soon as the "No Disk" message appears at the top left corner do the
following.
8. Press the REPEAT button - just above the TV channel selector at the bottom
right of the controller.
9. Enter 76884 on the number pad.
10. The region code "4" should appear at the top left corner of the
screen.(this just flashed on then off, so keep an eye on the screen)
11. Enter a "9" to make the player region free.
12. Power down and power up again.
13. Play a foreign DVD to verify the change.
Mar 22, 2013 | Samsung BD-E5400 - Blu-ray disc player
Can't connect Samsung bd-e5400 to network
put in network password and had an "unable to connect" message, turned the bluray player off and on again and then the network connection worked fine. I had to also switched to "manual", failed to manually assign an IP, then switched back to auto. 1 of those 2 things solved my problem.
Dec 25, 2012 | Samsung BD-E5400/ZA BLURAY PLAYER BD WISE...
Samsung bd-e5400 region hack
i have blue ray bd e5400 how to open region free please somebody help me
Nov 24, 2012 | Televison & Video
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
Problem with the Philips 42PF9431D/37 The screen won't come on and the power light blinks green for a few seconds then to red blink
1- bad scaler bd. 2- short or open fuse on t-con bd. disconnect lvds cable from scaler bd. to bd. on back of panel if stays powered u got it solved 3- swollen capacitors in power supply
Sep 09, 2010 | NEC PlasmaSync 50MP1 50 in. Television
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung Blue- Ray Disc Player With Bonus Hdmi Cable Bdd5250c, Wi-fi Ready; Logo
515 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
