Question about Dual Presidian DVD Recorder
DVD Recorder door sticks and the disc preparation process does not complete
I cannot record. The disc is read and then it begins preparing the disc, but it begins at 25% and fails before 30%.
    Problem Solver:
  • 10 Answers
Try to burn at the lowest speed possible or at one step lower speed that the one you are currently burning at.
Posted on Dec 27, 2013
Testimonial: "I cannot get to that point."
3 Suggested Answers
SOURCE: presidian dvd recorder pdr 3222
Have had the same problem with my Presidian3222 for the last year, if I recorded something it would come back as invalid disc or blank disc or would not close disc out right, got so damn mad almost took a hammer to it last night, unplugged it like clicky said, did no good, thought cable co may have been sending single to screw up recording, but today took camcorder and tried to record something, same thing which seemed to let the cable co off the hook.
the following seemed to have fixed the problem, first open the player then unplug it, close the drawer 1/2 way, then I took compressed air and blew inside the player to clean the laser after that I have been able to record 3 movies and close the disc properly and finalize the disc properly, I even had 50 new disc made by sony that recorded kept saying were invalid, reads them fine now, I hope this helps everyone, because I was on the edge of putting this thing in the trash last night.
R.J.
Posted on Mar 02, 2008
SOURCE: Presidian 3222
I don't know if this will help, but according to the operator's manual I have, on page 64, the only place it mentions "Full" or "Quick" Preparation, is when using a DVD-RW disc. Apparently, with this type of disc, you must use the Full or Quick preparation INSTEAD of Finalizing after you're thru recording onto the disc.
With the DVD-R and DVD+R, all you can do is "Finalize"; With the DVD+RW, if I'm reading this correctly, NIETHER Finalization OR Preparation is required.
But with the DVD-RW, apparently ALL you can do is a "FULL" or "QUICK Preparation.
If you're only getting "Erase or "Finalize" WITH the DVD-RW, then it appears there may be a problem with the machine.
Or, if you're attempting the "FULL or QUICK" Preparation with any disc OTHER than the DVD-RW, all you should get is "erase" or Finalize", since the QUICK or FULL Preparation is not done with discs other than DVD-RWs.
Hope this helps. I'm certainly not an expert on these things....I'm a "Vinyl" type guy.
Roy Davis
Posted on Jun 12, 2008
Liteon dvd recorder lvw1101 starts reading the dvd then says it preparing the disc then it ejects it
The Optical head unit is faulty. The disc is not being read by the head unit laser and so conveys a wrong message which ejects the cd.
Replace the optical head unit assembly but with the correct procedure.
Sep 11, 2010 | Lite On LVW-5045 DVD Recorder
I PUT IN A NEW BLANK DVD THE RECORDER PREPARES TO RECORD THEN AFTER ONE MINUTE IT STOPS RECORDING . I OPEN & RECLOSE THE TRAY & THE RCA RECORDER SAYS BAD DISC.
Some DVD players need to format the DVD+/- R disc before it can be used to record on this is a bit strange as its a WORM (write once read many) disc this is usually what happens with DVD+/- RW media.
If the DVD recorder doesn't finalize (the process that makes it compatible with other players) the DVD+/- R correctly then is will be rendered useless, another coaster for you to use with you cuppa.
I suggest that you use DVD+/- RW media that doesn't need finalizing at least until you can sort out your problem.
WRT your problem with it only recording for a short while it might be that the DVD stops spinning you might need to take the cover off and check this.
Jan 07, 2010 | RCA DRC8052N DVD Recorder
Unable to record
For several months I had a similar problem which was resolved using a cleaning disk. Finally that didn't help. I opened up the DVD recorder - removed a guard to prevent you from looking directly at the laser lens. I gently cleaned the lens with 91% alcohol on a cotton swab and now it records fine!!!!
Sep 02, 2009 | iLO DVDR05 DVD Recorder
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
My Liteon LVW-1105HC DVD recorder starts to prepare the blank disc but when it reaches 21% of preparring disc it ejects the disc
I had the same problem, I had to open up the covers (including the one covering the lens) and clean the lens with a soft cloth. Please be very careful while cleaning the lens since it is very delicate and any damage would permanently disable read/writes.
Aug 23, 2008 | Televison & Video
Presidian 3222
Roy Davis
May 31, 2008 | Dual Presidian DVD Recorder
LiteOn LVC - 9016G dvd recorder Problem.
throw it in the trash- I got 1 from costco, liked it so much, bought another a week later. First one started giving me the "invalid" msg, 2nd one did the same 1 wk later, so I guess they're programmed to do so after so many hours after being plugged in. Too bad, cuz it was the easiest to use of 5 previous models I tried. Their easyguide onscreen menu was the greatest, plus the status of time, pause & recording indicator, which you could turn on or off as needed, were very useful.
A real shame to have to throw in the trash. Won't ever buy another thing from them.
Nov 20, 2007 | Lite On LVC-9016G DVD Recorder/VCR
Lite on lvc 9016g will not prepare dvds or record
I have solved my problem with the LVC-9016G. I used OptiDisc
Laser Lens Cleaner for dvd Players. Both my units work fine now, with several different type of Discs. Hope this helps.
Oct 23, 2007 | Lite On LVC-9016G DVD Recorder/VCR
Televison & Video Logo
88 people viewed this question
Top Dual Televison & Video Experts
Jonathon summesfield
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
