Question about Panasonic PV-GS59 Mini DV Digital Camcorder
Broken LCD screen
Panasonic PV-GS59
Camera works fine. Can see through the eye piece, also the playback.
The screen is broken.
Can I replace the LCD screen? Where do I get the part and how much would it cost?
Is this something that I could do myself?
JDeRuvo
  • 48 Answers
SOURCE: Panasonic PV-D308 Palmcorder - no sound
It's probably not worth fixing. Camcorders are so cheap these days and it's high time you upgraded to a good miniDV camera or even a hard drive model.
You could try resetting the camera. See if there's a firmware update for it that may address the issue. Go into the menu to see if you accidentally muted it.
But if a repair is in order, rule of thumb is that if you get an estimate that is north of 50% what you paid for it, you're better off taking that money and buying a newer, more updated model.
JD
Digital Camera HQ
Posted on Dec 01, 2007
  • 3 Answers
SOURCE: Panasonic PV-GS300
DO NOT TOUCH IT! i took apart a vx1000 and broke more than i fixed. i wouldnt send it in either. just buy another camera. or **** and try to fix it. ITS hard work and onky if ur patient, should u persue the task!
Posted on Dec 24, 2007
bestdarngood
  • 3037 Answers
It is only one item that you are talking about above right?
Anyway to replace the screen (All brands are similar, the one I am most familiar with is Kodak which is what I am basing these directions off of), remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera to help prevent future screen cracking from accidental dropping.
Please Let me know if you have any further questions.
Thank you for using Fixya and Good Luck!
Posted on Apr 21, 2008
SOURCE: Need Software Drivers for PV-GS59
DO NOT PURCHASE THE PV-GS59 CAMERA!
Posted on Aug 11, 2008
SOURCE: LCD broken Panasonic PV-Gs 320
Hey, all.
I also have this problem, but have a little more to add:
Here is a website that carries the lcd screen: http://www.pasc.panasonic.com/Epartr/PartsList.asp
I think that its the following part number:
L5BDDYH00022 LCD DISPLAY (MONITOR) 87.56
$87.56 sucks, but it could be worse. Problem is now, I'm not sure how to replace it without taking the entire camera apart.
Let me know if someone does this successfully.
Thanks!
EAL
Posted on Jan 24, 2009
I want to transfer videos from the tape to my PC
please open this link and solve your problem.
http://www.retrevo.com/support/Panasonic-PV-GS59-Camcorders-manual/id/209ag012/t/2/
Feb 18, 2011 | Panasonic PV-GS59 Mini DV Digital...
I want to play and record my video from my Panasonic PV-GS59 to my computer. What driver do I need to download?
you will require a usbgrabber dongle and then easy to use software will be showbizdvd2 which retails for around R300,00 ZA comes with connectors and software you can also use is ULEAD software and connect via firewire cable or usb grabber dongle
Oct 13, 2010 | Panasonic PV-GS59 Mini DV Digital...
Software to edit video from camcorder, to use on
The best software to view, download, edit on Vista I have found for working well with PC and many cameras is called Videowave, great package indeed, is dead easy to use too and can cost less that £29.99 is most good computer shops.
Jun 10, 2010 | Panasonic PV-GS59 Mini DV Digital...
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
WHY MY LCD WONT WORK BUT CAN RECORD THROUGH THE EYE PIECE
send it in for repair. You may have pointed the lens at the sun while carrying the camera around and burned out the lcd.
Jun 27, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
LCD screen not working. Naybody know of an easy fix?
Connecting wires between LCD unit and main board of camera seems broken and needs to be repalced in your camera.
Jul 29, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
I bought a Panasonic PV-GS59 but it dose not work for vista
Apr 24, 2008 | Panasonic PV-GS59 Mini DV Digital...
My LCD Screen..
Your flat-wire connection between LCD monitor and the monitor PWB inside the camera is broken. can't fix it by yourself. Look for a Panasonic authorized service only!
Sep 20, 2007 | Panasonic PV-GS31 Mini DV Digital...
Panasonic PV-GS59 Mini DV Digital Camcorder Logo
43 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
