Question about Powerware 9120 UPS System
Rectifier and heatsink temperature sensor not ok for 9390 powerware ups system. When i switch on the 9390 ups a message appears which reads check rect temperature sensor and check heatsink temperature sensor. It goes in By pass but does not give any output.
    New Friend:
  • 37 Answers
It could be your uPS given the problem the mosfet might be spoil... as the temperture is high because of the transformer is not given the clean current to bypass the systems and the there not much air filter out from the ups depend on the condition of the room might be too warm.. there a higher chance was the mainboard problem well u check the sensor lst and also try to unplug and plug bk to restart the sensor... if it will not slove the problem check with the vendor to come down and check..
Posted on Jun 05, 2009
  • fei1976 Apr 19, 2011
    where is the temp sensor located at
Powerware 9390 UPS error configuration and circuit breaker battery check
9390 Requires a UVR type battery breaker. Unfortunately a configuration error will require a service visit from a technician. The proprietary service software will have to be used to reset this.
Apr 14, 2015 | Powerware 9390 UPS System
How to reset configuration error of the UPS 9390?
This error can only be cleared by the Eaton technician with their laptops. If this is a new unit it HAS to be factory started or your warranty will be void.
Apr 02, 2015 | Powerware 9390 UPS System
What is the password for a powerware?
You will have to consult the user manual for the default password. Usually default passwords are admin/admin.
Oct 16, 2013 | Powerware 9390 UPS System
Notice: UPS ON BAYPASS, ERROR CONFIGURATION
Need to configure upon initial startup
May 21, 2013 | Powerware 9390 UPS System
Message comes up on restarting reads configuration error. What is the cause and possible solution?
There is alot of possibilities on this on. Most likely it is in your input or output. You may have a 208V or a 480V input but your UPS may be programed for 240 or another voltage. I have the manual and all the knowledge you need. Email me at ericpettingill@hotmail.com
Sep 16, 2011 | Powerware 9390 UPS System
I had an alarm on 9390 which read : "Battery Test Fail". What would possibly cause it and how would I best prevent it from reoccuring.
This error indicates that the battery packs are no longer able to supply the expected run time or load capacity that the UPS needs. The batteries will need to be replaced.
May 11, 2011 | Powerware 9390 UPS System
I WOULD LIKE TO BUY A NEWPowerware 9330-40kva UPS UNIT, COPLETE WITH BATTERIES .how much would that cost?
It's unlikely that you will be able to get a new one. The 9330 was discontinued many years ago though Eaton continues to service these models and provide replacement parts/batteries. I suggest that you call 800-356-5794 to see if Eaton has a partner that has any complete systems still in stock or in service inventory. The new UPS units are the 9355 and the 9390: www.eaton.com/9355 and www.eaton.com/9390 These new units are more compact, are more energy efficient and incorporate more advanced technology for monitoring and communication.
Mar 11, 2011 | Powerware 9330 40 (A40401110031112) UPS...
No Power Up
The battery charger inside the UPS is faulty so check the transistors including the rectifier on the heat sink. Replace the faulty ones and your UPS will be good. I strongly suggest that you check all the transistors on the PC board just to make sure that the whole board is ok after replacing the transistors
Mar 25, 2009 | Powerware 9120 UPS System
No Power
You should measure AC voltage from the output of the transformer to the bridge rectifier, and after the rectifier you should see a DC voltage (you may also read some "ripple" AC voltage on the DC side as well). Check across each battery to see how many volts DC they are receiving (as they will all be in series connection ie one after the other). Batteries are the usual problem with faulty UPS's. You may have a problem battery or multiple problem batteries and they may need replacing.
May 06, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
212 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
