Electrolux ewt 10410W
Washing machine doesn`t start ; "Start" push button blinking (green color)all the time. When press "Start"push button indicate "Error" without any number on the diplay and after while "Error" disappear. I used service test and display show fault E66. What is mind?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Posted on Dec 27, 2013
SOURCE: wf860p computer control automatic
I have had this problem it is caused by accidentally pressing both the on and start button together. It puts the machine into demo mode. You need to press both the buttons together again for about 30 seconds. If it doesn't work first time switch the machine off and do it again. Sometimes you have to do this many times before it works but eventually it does work.
Very frustrating.
I found the cause was either leaning on the front of the machine or resting a broom which when you pick it up accidentally presses the two buttons.
Posted on Nov 22, 2007
  • 123 Answers
SOURCE: Need Manual for Electrolux EWT 13420 W - EWT 10420
These site carries the full line of Electrolux Manuals
http://userguides.50webs.com/manual.htm
Posted on Sep 06, 2009
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
  • 6 Answers
SOURCE: Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Posted on Oct 17, 2009
SOURCE: Test Error
Hold In on/off and start buttons together for 10 secs.
Posted on Feb 21, 2010
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Start button does not activate door lock and will not turn on
It may be a micro switch that is not engaging. Try pushing on the door to see if that solves the problem. If so, put in a spacer to push the switch more.
Jan 24, 2015 | Bosch Nexxt300 WFMC220 Front Load Washer
Electrolux ewt 115
Hi Cong Tran.
To buy parts for your machine you should go the the manufacturers distributor with the full model number. (The shop where you bought the machine may be able to help you with that information) The parts shop can easily tell you cost and availability of the part.
Good Luck
Cheers
Nomess
Jan 03, 2015 | Electrolux Washing Machines
Ewt 905 manual
my ewt 905 couldn't start at all when i switch on power. but i tried my other devices on that paticular socket and it works.
Jan 18, 2014 | Electrolux Washing Machines
Ge washer tl1103pbwn
The washer uses a green light, which is the "Start" button, to indicate problems, and the flash pattern is a code to the type of problem. Two flashes means the washer's drain pump must be cleaned. Clumpy or poor-quality detergents can clog the drain pump. The user can attempt to fix the pump, but, If the problem continues, he must contact the GE customericon1.png service line for professional service.
Read more: http://www.ehow.com/how_12129638_troubleshoot-ge-washing-machine-green-light-flashing-two-times.html#ixzz2qLdypTQ0
Jan 13, 2014 | Washing Machines
I have an Electrolux Washer machine model EWT959 and it currently problem is:- 1. "Choose Program & Start" 2. Once "Start/Pause" button pressed to start the wash 3. The message on...
It doesn't think the lid is actually closed indicating that there is a problem either with the lid lock or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Oct 06, 2011 | Electrolux Washing Machines
RESETING THE FULL ABSORBER
Waist reset code
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down POWER button, let go of the RESUME button and then press the
RESUME button twice in succession. Then let go of the RESUME button and POWER
button.
(Each time you press the RESUME button, the indicator's color toggles between orange
and green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the stipulated number of
times to execute the desired service function listed below.
press 4 times indicator light should be green, this Clears the waste-ink counter.
4) After selecting the service function, press the POWER button. The green indicator
lights and the service function will be executed.
(After the respective function is executed, the printer returns to the service function
selection mode.)
To cancel printing after it begins, press the POWER button.
The Power lamp will blink for a while and then stay lit. You can then select
another service function.
Oct 22, 2009 | Canon Office Equipment & Supplies
Washing Machines Logo
310 people viewed this question
Top Washing Machines Experts
