Question about Gemmy Life-Sized Animated Santa
Santa will not click down or stand all the way up what is the problem
Santa will not click down or click up...What do I do I can't pack it away and it won't stand up completely...Help
    Guru:
  • 154 Answers
Hi Penny,
Did you try pushing down on his shoulders? If you remove the screws from the base and apply pressure to the shoulders he should able to move into an upright or down position. If that doesn't work try looking at the instructions. Maybe they will help you take it apart: http://www.fixya.com/support/p1879030-gemmy_gemmy_life_sized_animated_santa/usermanual-A057EBE-pdf
Posted on Dec 30, 2013
3 Suggested Answers
  • 4 Answers
SOURCE: how do i keep my airblown santa standing?
I would put a tether in front of him also
Posted on Dec 03, 2009
  • 16 Answers
SOURCE: i have a homer simpson santa inflatable 3 years
you could try hair spray not sure it would work but it just may
Posted on Dec 21, 2009
My Santa quit dancing what can it be?
this is what i found on the internet...
hey i got one of those santa's too that stopped moving. found a rubber belt to be the issue. takes a bit to get him apart to repair (removing arms, clothing, and mid body & head to leave a stand with a rectangle box that moves the santa body i havent fixed mine yet last time i tried i added lots of vasaline to areas that move / rub but didnt help. am going to try new belt when i can get one. Did your santa sound distorted when he stopped moving?
or try this link.
Repairing Singing Dancing Santa
or this one. My Santa quit dancing what can it be Google Search
Dec 14, 2016 | Toys
Need parts list for Santa
Hyundai Santa Fe Parts - Auto Parts Warehouse
www.autopartswarehouse.com > Hyundai
Aug 15, 2014 - Need help with your Hyundai Santa Fe parts? Browse our site or give us a call and we'll surely help you out. Get that part right away.
Hyundai Santa Fe Parts - Autohaus AZ
https://www.autohausaz.com/hyundai...parts/hyundai-santa_fe-parts.html
Navigate through our extensive auto parts catalog to find all the maintenance parts youneed. Save the most money you can buy purchasing your Hyundai Santa ...
Jan 18, 2016 | Cars & Trucks
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
Dec 01, 2015 | Toys
Hi, Car will start fine and runs perfect, however after a long run (1/2 hour or more) wont start straight away wait 10 mins and away it goes, turns over fine just doesn't fire
Loss of spark ? CK coil or coil pack or ignit relay. Any CK engine lts? coolants sensor or temp sending unit.? Is it running hot?
Sep 04, 2015 | 2003 Hyundai Santa Fe
My life size Santa stopped dancing. How do I fix?
The first step would be to check all of the connections. If they are fine, next is to check the power supply for voltage using a meter.
Dec 03, 2014 | Gemmy Life-Sized Animated Santa
How do you get to the spark plugs 2005 hyundia santa fe
There's a plastic cover on the valve cover, remove small bolt's holding cover, under cover will be two coil pack, and a total of 4 spark plug wire's, remove small bolts to coil pack, will have two bolts to each coil pack, disconnect elec. harness, remove coil pack, spark plugs will be in there.
Sep 20, 2010 | 2005 Hyundai Santa Fe
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
2004 hyundai santa fe drain plug
Hi
I am very assumming that you are looking for the drain plug for the rad, right? It is located in the bottom of the rad, right side of rad standing in front of it. You can excess it with a philips scewdriver through a hole in the sub frame.
Jan 09, 2010 | 2004 Hyundai Santa Fe
I need instructions on how to pop up my gemmy animated singing santa
It is suposed to pop up once you press on its shoulders. Once you press them both down you will hear two clicks and release and it will pop up. Mine was jammed and when I pressed it down on the shoulders only one side would click, the other side would not click so Santa did not pop up to full size.
It was jammed on the white area of the stocking, the material got tucked inside the click mechinism prevent it from making proper contact. To fix it I simply pulled the white stocking material up (as if you are going to roll the pant leg up) and then when I pushed the shoulders down after that it opened up just like it should!
Dec 16, 2009 | Gemmy Bing Crosby Big Head Doll
Gemmy Life-Sized Animated Santa Logo
143 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
