Question about Oral B Vitality Dual Clean Rechargeable Electric Toothbrush Colors May Vary
I have a new oral b vitality toothbrush. I've had it plugged in for more than one day and it still is not charged. It is not an outlet issue as I have tried different outlets
When plugged in there isn't a red light at the base to show that it is charging
3 Suggested Answers
johndoe541
  • 784 Answers
SOURCE: My Oral B Vitality Sonic
ther is maiby some conection problems.
Posted on Mar 03, 2011
SOURCE: my oral b rechargeable toothbrush
The plastic connecton has a coil in it, much like how a transformer is done. If you read up on how a transformer works its pretty much the same principle as it works on Induction. There is a coil and core iron in the end of the toothbrush and in the base, this creates AC current which inturn causes induction to flow through the coils and charge the battery. And about the reason why it is not charging is probably down to the battery being flat ( happens even when new ) or there is a loose connection when it was being transported.
Hope this helps.
Posted on Mar 22, 2011
Electric rechargeable braun toothbrush 500
I had the same problem at the beginning of the year. I think i had bought 3 electric tooth brushes and all seemed to cave in within a couple of weeks. My friend recommended going to Macy's to buy one, which I did and it is still going strong. Maybe you charged it for a very long period of time and it overheat the system circuit? I'm not sure but I would recommend getting a new toothbrush.
Jul 04, 2012 | Oral B Braun B Professional Care 500...
My braun toothbrush will not charge it is the 5. in a year. I am very fed up with Braun Oral B. Why is it not charging. Bought this one 5 weeks ago.
Have you left it to charge for a long period of time? Maybe it overheated the power source? If you cant get it to work I would suggest buying at Macy's. They seem pretty reliable and have good warranty's for these sort of things.
Jun 30, 2012 | Oral B Braun B Professional Care 500...
Why is my oral b braun B Professional care 500 not charging
Test the voltage of the charger base. This is a simple method to see if your brush is getting power from the base. Touch the metal connectors with the voltage tester. This should light up the tester. If not, it is losing electricity somewhere within the base.
Apr 23, 2012 | Oral B Braun B Professional Care 500...
Lost instructions for use of oral b dual head vitality toothbrush
If you mean the Vitality Dual Clean toothbrush, you may download the manual here.
Dec 30, 2011 | Oral B Vitality Dual Clean Rechargeable...
My oral b rechargeable toothbrush (brand new out the box at the weekend) wil not recharge - have thrown the intructions away thinking "what is there to know you stick the toothbrush on the charger...
Hope this helps.
Mar 22, 2011 | Oral B Vitality Dual Clean Rechargeable...
My oral b vitality toothbrush is not charging. Is it because of the battery? Can I change the battery and if yes how?
Many bathrooms are fitted with protected outlets. Some Oral-B units will not charge properly with some protected outlets.
Jan 11, 2011 | Health & Beauty
My Braun Oral-B Sonic Complete Toothbrush wont hold a charge
I had the same problem today. I use the charging plug which has the "wrench" remove the bottom screw...I was attempting to remove the battery to reset the brush. I could not get the bottom of the brush off as I did not want to use a screw driver or similar to pry it off in case I needed to return the brush.
So I was trying to pull the bottom off and my finger was on the on/off switch, as I was wiggling the bottom of the brush to try to dislodge the battery it started working.
The brush seems to have a reset button on the back but that did not do anything. The display also has moisture trapped inside it, which I am sure is not good!
Any way try this and maybe the battery will come out and I am sure that will reset the brush...if not maybe you will get lucky as I did and wiggling it will work. BTW, this is with the Oral-B Triumph Professionla Care 9000
Apr 21, 2008 | Computers & Internet
Oral B Vitality Dual Clean Rechargeable Electric Toothbrush Colors May Vary Logo
26 people viewed this question
Top Oral B Health & Beauty Experts
Jonathon summesfield
Dan Apthorp
Are you an Oral B Health and Beauty Expert? Answer questions, earn points and help others
