Question about KTSKaraoke Nuvoice v-280 dual channel wireless microphone
Microphone system We bought Nu Voice V280-1 Frequency set of microphones and have them hooked up to the Nu Voice receiver to our iMac and then over to our Onkyo receiver via HDMI cable to our Bose system. There is a daly between the input and output of the microphones which is annoying and I was wondering if there were some adjustments that can be made or do we need to nut something else to make the sound better ??
L4diversity wireless receiver adjust frequency shure and microphone sm58
Sorry, it's not possible to adjust the frequency of the L4 wireless receiver. These were single frequency, crystal controlled systems. To change the frequency would require changing a dozen components on the board and then retuning the filters on the receiver board to work with this new frequency.
Aug 07, 2014 | Shure Audio Players & Recorders
Samson cr77 uhf insrtuctions
The microphone has adjustable wheels, usually behind the batteries in the battery compartment. The wheels/switches allow you to set a frequency. Set the reciever unit and the microphone for the same frequency. Make sure the batteries in the mic are charged.
Sep 05, 2013 | Audio Players & Recorders
How do I connet the Bratz Rock Angels cordless microphone to the receiver?
Thank you for your question. The microphone broadcasts to an FM radio at 100.1 MHZ. I would suggest you tune your radio to 100.1 MHZ. While holding down the microphones Vox button, take a small screwdriver and slowly adjust a small screw by the battery compartment on the microphone until you hear your voice over the radio. Adjusting the screw changes the transmit frequency on the microphone.
I hope this helps. I would appreciate your taking a second to rate my assistance below this posting. I look forward to hearing your voice over the radio as you work your way to the top of the music charts! :0)
Jan 23, 2011 | Toys
I bought a new T2 SM 58 Shure Microphone with freq. 171.845 Need a receiver. Don't know where to go.
Unfortunately, there are no new receivers available that can be used. You'll have to try to find a used Shure receiver on that exact frequency.
Dec 21, 2010 | Shure T2/58-CL SM58 & Wireless Transmitter...
Hi i have this system 2X Shure LX4 Wireless MARCAD Receiver + SM58 Microphone can i buy seperate SM58 MICROPHONE to use in this system? thx. mike
The LX series was discontinued by Shure several years ago. They no longer have any new transmitters that would work with your receiver. You could look for a used transmitter, but it would need to be on the exact same frequency as your receiver. That will not be easy to find.
Dec 20, 2010 | Shure LX-2 With SM58 Professional...
Problem with Installing Mike at Same place morthen one mike
Hi, frequencies can easily jam when the mic that your using has the same frequency response or alike response.
You can check if the sensitivity response on the receiver is alike or the same. Usually represented with numbers on the receiver. If they are alike, it is likely to fluctuate.
Take care.
May 31, 2010 | Beyerdynamic Opus 381 Professional...
Whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
Connecting external microphone to imac g5
Get yourself a great little gadget called iMic. It's a usb connector that adapts to let you used your headset mic and the mac system os will recognize it very well. Works good .
Costs about 24 bucks or so..
K
Jun 19, 2009 | Apple iMac G5 Power Supply 661-3351
Wireless Microphone low volume
The PGX1 bodypack has a switch on the side to set the gain. Make certain that switch is in the "mic" position. Otherwise, simply turn up the volume on your mixer.
Jan 24, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
The Disney Hanna Montana FM Microphone
The radio needs to be set to a specific station (its listed on the packaging) What the microphone essentially does is override the broadcast on that frequency and allows you to hear yourself. Its the same principal as the '80's classic "Mr. Microphone".
Dec 13, 2008 | Licensed Disney Hannah Montana Wireless...
KTSKaraoke Nuvoice v-280 dual channel wireless microphone Logo
204 people viewed this question
Top KTSKaraoke Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a KTSKaraoke Radio Communication Expert? Answer questions, earn points and help others
