Question about Brother MFC-8440 All-In-One Laser Printer
I need a new ADF (automatic document feeder), where can I get one?
Please help me find an ADF.  Is this something I can install myself?
  • Anonymous Feb 21, 2008
    My MFP 8440 all of a sudden will not feed from the ADF. The light went on saying Open Document Feeder...but I found a switch which then pushed shuts off this, but documents will not feed. Everything else works great.
    Any suggestions
  • Brother Master
  • 1,113 Answers
ADF can be bought from a dealer, it has a few cables that need removal so it is a little tricky, it is also a expensive part (approx Aus$200, why are you replacing it, are you sure you dont just need to clean feed rollers or there is also another common fault on these doc feeders, the left side hinge breaks( replace hinge)
here is the brother part number for the adf (complete), you will need to purchase from a autherised brother dealer -
LE8659001  DOCUMENT COVER LGL ASSY
Posted on Oct 17, 2007
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
What voltage should be read on each pin of the power adapter?
hello ,, this information is based on ScanJet 5400C - (C8517V) -- if yours is other p/n, let me know
North American use , C8517-84200, Low power AC power module (Wall Mount Type) - 100-120VAC, 60Hz - Detachable power cord not needed (USA, Canada) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
European use , C8517-84201, Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (Europe) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
Worldwide use , C8517-84201, Low power AC power module (Brick Type) - 100-240V input - Requires a 3-wire detachable power cord - For worldwide operation - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
i hope thsi helps -- if it does, please rate my service
Nov 13, 2010 | HP Scanjet 5400c Flatbed Scanner
I have a message coming up that I don't know what it means.
ADF = Auto Document Feeder (Usually on top)
RADF = Rear Auto Document Feeder, (On the back)
Something is stuck in one of these, a piece of paper, foam, paperclip, twist tie . . . it could be anything. Follow the squealing sound and check the paper feeder rollers.
Find what is in the way and remove it.
Cheers.
Jun 22, 2009 | Toshiba e-Studio 161 Copier Copier
Automatic document feeder does not work-- does not pick up paper
Here, you will find information on feed issues with the ADF. If you still have problems, you can find information on the "clear jam" error here.
If the above fails, you can find information on paper pickup issues and also how to perform a partial reset here.
Hope this helps. Please remember to rate this information.
Thanks
May 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Doc.feder jam
Try cleaning the rollers in the ADF (Automatic Document Feeder).
It might temporarily solve the problem, but rollers do have a limited life time, so you will eventually need new ones.
Part info:
5851-3580 - Automatic document feeder (ADF) paper pick-up roller assembly
Price: $15.57
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
Brother MFC-8440 All-In-One Laser Printer Logo
305 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
