Drive for TSSST CORP CDDVDW TS-L633J
THE CD player can not can not be read by the computer. I THINK THE DRIVE FOR THIS IS OUT OF DATE OR CURRUPTED.Toshiba satellite C660/C660D. Where can I download new drive.
    Brigadier General:
  • 3,400 Answers
CHECK SO THE DATA CABEL NOT LOSSEN.
CLEAN IT WITH COMPRESSED AIR.
GO TO DEVECIEMANAGER AND UPDATE THE DRIVER.
Posted on Dec 27, 2013
kikoksky
  • 119 Answers
SOURCE: error 2131
try this:
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution');
Posted on Jun 20, 2008
adnanbhatti
  • 1188 Answers
SOURCE: Cannot Burn (HP ProBook 4510s CDDVDW TS-L633M)
Do you mean that you cannot burn the CDs altogether or it just produces errors during burning.
In either cases most of the time cleaning the lens with a CD ROM cleaner helps.
If it burns but gives errors then try another brand of CD-R. Use a slow burn speed when burning, it can be helpful. Try using another burning software.
Optical media and drives are getting increasingly cheap. If it fails often consider purchasing a new drive.
Posted on Sep 11, 2009
  • 15 Answers
SOURCE: After installing Samsung's TSST corp CDDVDW
Please be sure that your writer writes DVD's also confirm once again from where you've bought it..
If its surely the Right one then try some other Image burning softwrae don't use Nero its not good..
Posted on Mar 25, 2010
thbestofme
  • 64 Answers
SOURCE: My TSST Corp CDDVDW TS-L632N ATA DEVICE is not
first of all is the device getting detected in Computer.. if yes.. then try to update drivers from device manager.. if not then try to delete upper filter lower filter from registry editor.. to do so follow the steps below
  1. Click Start vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in thePrograms list.
    securityshield.jpg If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
let me know if this resolves ur problem.. regards, guru
Posted on May 05, 2010
SOURCE: Dell Optiplex 755 machines - TSST corp L632 drive-won't read CDs.
make sure that you are closing the CD and also make sure that the cat isnt licking the dogs balls while your doing it.
Posted on Nov 10, 2010
To clear hard drive of web browser sites and cookies
If you are using Internet Explorer - version 10, go to Tools, Internet Options, General, Browsing History then select Delete.
Jul 24, 2014 | Toshiba Satellite C660 C660D laptop...
Need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Jun 06, 2012 | Toshiba satellite c660
I need a user manual for a toshiba c660d-150
Here`s the link.Just fill up the drop down box so that you can download the manual..
MANUAL for Toshiba c660-150
Sep 13, 2011 | Toshiba Computers & Internet
How can i connect toshiba satellite c660d-155 to t..v
On the top row of the function key aka "F-key",you will see there are logo for a TV is different.
You need to HOLD the function (FN) and press the dedicated TV (function key) to enable the HDMI port on you laptop.
Sep 05, 2011 | Toshiba satellite c660
My LAPTOP is Toshiba Satellite c660/c660d Webcam is not recognized by the laptop. Under device manager it is considered an unknown device and I can't seem to find any drivers
Hello!
Please go to Device Manager, right-click the Unknown Device and click Uninstall. Then up within icons you will find Scan for Hardware Changes icon (menu with arrows, show/hide, help, show/hide, scan)>click on the icon and it will run installation wizard after scanning. You will probably need to restart your computer after the process is done.
Regards!
Jun 28, 2011 | Toshiba Computers & Internet
Toshiba satellite c660-1el drivers download for windows 7
Check out this link @ http://za.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=ZA
Make your selections for your download as below from the link above:-
Product type : Notebook
Family
: Satellite
Product series
: Satellite C Series
Model: Satellite
: C660
Short Model No
: PSC0SE
Operating system
Driver type
: All
Country
Language
: English
Hope it helps.
May 27, 2011 | Computers & Internet
My sound isnt working on my toshiba satellite C660/C660D
What Operating system do you have? If its win 7, go to start then type device on the start search box and you'll see device manager at the top. Click on it then look for audio driver, right click on it then uninstall. Restart your comp. and it will automatically reinstall the driver.
Mar 16, 2011 | Computers & Internet
How do you open the webcam on a toshiba satellite c660/c66od laptop
It depends on what software you have installed for it. If you don't have any software installed for the web cam, you can find plenty of freeware out there such as http://download.cnet.com/Acer-Crystal-Eye-webcam/3000-2108_4-188685.html
which will allow you to view / use your device. You may try exploring your programs menu and looking under those that start with "Toshiba". Vendors typically bundle some software to showcase the hardware they give you in a computer...
Mar 02, 2011 | Computers & Internet
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
