Samsung LNT5265FX 52 in. LCD Television Logo
J
Jeff Schmidt Posted on Dec 27, 2013
TV has audio, but displays only random colors and color bars. Menu doesn't function
Was repaired once before under warranty for this exact problem. In that case, the PC board was replaced.
  • Jeff Schmidt
    Jeff Schmidt Jan 02, 2014
    Update: LCD Panel is bad. After being off for a good while. The TV functions momentarily after power up, but once the panel heats up, it starts pulling voltage from the main board. Not worth repairing.
5 Related Answers
HDTV GURU
Jay Henderson
  • 261 Answers
  • Posted on Mar 22, 2008
SOURCE: New Samsung Plasma HDTV
That is what is called BURN IN or as the manufactures call it "IMAGE RETENTION". Basicly what this means it that you have been putting more hours on the part that is darker the smaller part, or the 4x3 picture or the square part. And, basicly the part that appears to be lighter is "LESS" worn out than the other part of the plasma tv. There is no fix for the problem, But if you go into the menu and select "BURN-IN" OR "Pattern sweep" or WHITE Screen than you will see exactly what i mean. Now, you can keep it on this pattern overnight if you would like, but i suspect it will not cure the problem, but lessen the effects of it. But keep in mind, you are reducing the life of the complete panel when you do this. Not that it is bad to do this. If you have anymore questions don't hesitate to ask anymore questions. The better fix is to Switch over to the "Dish Network and than you can format the screen on any channel in any mode. Superior product to cable. Have a great day. And watch out for the snow storm coming. GURU JAY
Anonymous
  • 22 Answers
  • Posted on Apr 28, 2009
SOURCE: Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Anonymous
  • 1139 Answers
  • Posted on Jun 10, 2009
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com [email protected]
panchal643Ja
Jayesh Panchal
  • 280 Answers
  • Posted on Jan 23, 2010
SOURCE: samsung ln32a450c1d, 2 yrs old--bought at circuit
If you can open your LCD and clean all connector given and refit properly.don't use force to remove connector just try to softly remove.
james tv man
James DuPont Jr
  • 91 Answers
  • Posted on Jun 07, 2010
SOURCE: My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Large yellow spots floating across TV screen
Adjusting the Color Temperature
Color temperature refers to how red (warm) or blue (cool) the color palette is. This control helps you to adjust the color settings on your TV. You can change the color settings by following these steps:
- Using the TV remote, select settings and look for a menu item labelled video or picture.
- Select Color Temperature. A slider should appear that allows you to slide between cool and warm colors. The colors might also be labelled red or blue.
- Slide the settings away from red/warm and towards blue/cool using the remote control. You can leave the slider at the point where the color is most pleasing to you.
My Toshiba 42hp83 has a rectangular area of the screen that changes colors randomly from the left-center of the screen down to the bottom. After about 20 minutes of the TV being on, the problem usually...
We had a similiar issue with our SAMSUNG Plasma TV. It had a 2'or 3" vertical bar of random colors on the right side of the screen. It would also go away but then come back. Fortunately for us the TV was still under its original 1yr manufacturers warranty. We called the customer support and they scheduled a service call. The TV repair man took our TV to the shop and replaced the defective components. It took about 3 weeks for the repair.
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Sony FWD50PX2 screen displays color noise
Hello Zirben:
You will ned to have your Tv looked at by a repair shop there seems to be a problem with the small singal board.
The Slash
3answers
My HDTV wont turn on, two weeks ago the colors blend together I wasen't able to adjuste the colors. then I turn it off and leave for two weeks. when I try to turn it on it wont turn on, the control panel...
It seems that you have an issue with the power board. You could also have faulty convergence modules causing the blending of colors.
I wouldn't advise you to open the set yourself, because of the complicated circuitry and high voltage. It is safest and best to get TV repairman to look at this issue and provide a fix/repair.
Monitor display had problem .
Hello Lunhoo,
Your TV should still be in warranty. If so, yes you should take it in for repair. Even if it's not in Warranty, Akai may have a special warranty extension for your TV. Check it out.
Good luck.
Color blurry
If it is in in the menu aslo one of the main boards are defective. Contact Philips @ 1888-744-5477 and the will do the repairs in the set is under warranty if just out of warranty they will still help have your receipt.
1helpful
2answers
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
