Question about Whirlpool GY396 Electric Kitchen Range
Zopey1962@hotmail.com changed out the temp. sensor and the oven control board. the oven is not cooking the food right it is either burning the top r the bottom of the food. sometimes it works fine. sometimes it will not work at all. would not work-pushed it back against the wall (hard) and it started working again. so it either does not work R it burns the food R it works fine....any suggestions.
4 Suggested Answers
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
SOURCE: Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Posted on Nov 24, 2008
  • 126 Answers
SOURCE: Whirlpool RF368LXMQ Overheats; Displays F3E2
I'd start with testing the oven sensor that if that is bad it wont be horrible because you'll have no problem replacing it yourself less than $100. That is where I'd start let me know if it works. Good Luck.
Diane
Posted on Jan 16, 2009
Oven burning food
Get an oven thermometer and measure the temperature in the oven to determine if it is at the correct temp or not. If not then there is an oven problem possibly the oven temp probe or the oven electronic controller. If the temp is correct then you are doing something wrong as a cook such as oven temp set too high or cooking for too long.
Nov 19, 2013 | Hotpoint Kitchen Ranges
My Maytag convection oven has the heating elements on the top. It doesn't matter if I use convection or not, metal, nonstick, or stone pans, or lower the temperature or cooking time, it doesn't cook/bake...
Stick a thermometer inside the oven. Compare the them inside the oven to the temp you see on the control panel; are they the same?
You must do this first. You will note a disrepancy. If the oven temp and yours do not match, that you have solved the problem.
Your oven sensor or thermostat might be at fault.
Oct 20, 2013 | Maytag MGR5770 Gas Kitchen Range
Top burner over heated and burned our food then E2 F3 fault showed up on keypad. Burns the outside of the food but does not cook the inside. The oven was on bake not broil. Model GY396LXPS00
Hi.
E2 F3 means Oven temperature is too high (Cook mode).
The first part to be tested is the temp sensor. The sensor is located inside oven cavity and it is tested using a multimeter set on Ohms to read impedance at sensor contacts.At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, check for a short to in element wiring (element stays always on). If element and sensor are OK replace the control.
Regards.
Ginko
Jun 10, 2011 | Whirlpool GY396 Electric Kitchen Range
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
Large oven burning food on top shelf when in fan assisted mode
Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
If you must cook that high up in the oven, then cover the food your cooking with foil.
Dec 16, 2009 | Kenmore Ovens
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Oven consistently burns food no matter what temperature setting
Well, must confess, we had this problem once, after cleaning all the knobs. We put them back, reversing the two temp knobs. The correct placement, we found, was the left oven knob, since it is not self cleaning, does not have the word CLEAN. This is the far left knob. Next, from left to right, appearing very simmilar, also with temps 200 to 500, is the right oven temp knob, which does say CLEAN. Third from left is the right oven function knob, with CLEAN, Time Cook, etc, and no temp numbers. Hope your fix is this simple. Hope your cooking is looking good cooking.
Dec 07, 2008 | Jenn-Air Kitchen Ranges
Not cooking completely
replace the oven temp sensor. it looks like a probe that is in the oven, at the top
Jan 25, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Whirlpool GY396 Electric Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
