Question about Viking Refrigerators
Can't clean out spilled (and now sour) milk spill
Apparently a significant amount of milk spilled in our Viking side-by-side refrigerator (48", I believe). We've removed all of the shelves, drawers, etc., and cleaned out what we can. However, it appears that the milk has also seeped into the bottom of the fridge, perhaps through the screw holes for the drawer rails on the bottom? Is there any way to remove the bottom of the interior of the fridge to clean out the rest of the milk? Is there any way to get underneath the fridge to clean it out? Thanks!
    New Friend:
  • 33 Answers
Hi, I'm not familiar with these fridges, but is it possible to access it from the back, underneath the evaporator tray? It could even be that the milk has gone down the drain hole and into the evaporator tray itself. Its a small flat plastic tray that has raised sides, and will probably have water in in, sits just above the motor
Posted on Dec 27, 2013
  • Steve Lessnick
    Steve Lessnick Dec 28, 2013
    Thanks for your reply! I got underneath the fridge from the front, and found the evaporator tray, but it's under the freezer size, not the refrigerator side, and there's no milk in it. At the moment I can't get to the back of the fridge because of how it's installed. I see a lot of electrical/mechanical stuff underneath that's mounted to the underside of the fridge. I guess there's a space between the metal housing that holds the electrical/mechanical, and the inside of the fridge itself. I'm thinking that I'm going to need to call a repair-person. Ugh.
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
lenwest
  • 150 Answers
SOURCE: Have the Kenmore Elite commercial refrigerator,
Try a sponge using gloves.Add hot water and continue with the sponge.
Posted on Feb 21, 2009
57 varieties
  • 1653 Answers
SOURCE: I have an Electrolux side
On our side by side we had to lift the shelf up or out to be able to remove the drawers. They are very fiddly and some patience is required.
Posted on Nov 08, 2009
  • 10865 Answers
SOURCE: Milk which was spilled in the fridge has dripped
Hello. yes. The tray can be slid out. Before you do this, unplug your fridge. Then remove the lower front grill, it just lifts off. Grasp the tray and gently pull it forward. J.
Posted on Jun 22, 2010
SOURCE: GE profile bottom freezer fridge smells (milk in back vent?)
We have the exact same problem! Did anything work??
Posted on Jan 08, 2011
How can I clean under a car seat that milk was spilled on?
You might want to try a detailing shop. They have commercial products for just such a problem.
If the spill was in the fabric where a person would sit, it is in the foam padding too. And could have run down into the seams.
Nature's Miracle which is available at pet stores, or lemon juice and water will help cut the smell that remains.
Jul 25, 2013 | 2009 Hyundai Sonata
A carton of milk spilled in the refrigerator draining into the evaporator pan which cannot be accessed. any suggestions to eliminate the sour milk smell
take unit outside........ flush drain evap pan out with warm water and clorine bleach..hope you get all dry residue out......or take it apart and wash out evap pan...can you get to it from underneath???? easier.
if you do not remove milk residue you kitchen will smell forever...remember baby smells????
Feb 19, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Spilled milk under the rear seats in my 2006 Ford Fusion SEL.
its not hard, the seats are meant to be removed fairly easily, there are two latches under the seat about a foot in from each edge that have to be released (i think you just reach up under and then its just like a trunk or glove box latch, then push back on the seat and lift up on the front and it should pull out.
Oct 04, 2009 | 2004 Ford Fusion
Smell under the unit, kenmore elite model number 44703
Hi: Not knowing your model number I would look where the milk was spilled and see if there is a hole. Possibly behind a panel for the defrost water. If so pour a little clorox bleach ane water in it. If not look for any cracks in the liner of your fridge. Those will expose the foam insulation to absorb the milk and cause odors. Clean them and seal them with teflon tape or a repair kit from the manufacture. On the off chanch the mild spilled to the front of the fridge and leaked behing the front grill the coils there are quite warm and will spoil milk fast. Pull the grill off and clean. I hope this helps, Jeff
Jul 07, 2009 | Refrigerators
There is a bad odor blowing out from under my Whirlpool side-by-side refigerator. How do I fix it?
Hi
Odors in the refrigerator can come from many different sources. Spoiling food, spilled milk, open food. Often a really good cleaning out with an ammonia cleaner can help or with a baking soda water mixture.
But, sometimes an odor can "permeate" into one of the plastic parts found inside the fridge, crisper pans, door liners, shelf supports. Even after you have found the spoiling food, removed it, cleaned the fridge up.....sometimes another plastic part will pick up this odor and continue to give the odor back off. A few things that can help with this type of an odor, place one these inside the fridge section:
- box of baking soda
- dish of coffee grounds
- open slices of bread
The bread trick can be used to effectively to remove odors. Just throw a slice or two onto one of the shelves in the fresh food compartment, leave the bread slice(s) in there for 12-24 hours -no longer- and then throw the bread out or I throw the bread outside for the birds to eat. When bread goes stall, it will **** in odors very well. Because the air inside the refrigerator is blown between both sections, this will help the fridge and freezer sections. Do this for about a week and you should notice a big change in the odor problem :-)
A really bad odor problem. Sometimes something like milk or juice is spilled inside the fridge. The liquid can run under the plastic edge breakers and get into the insulation. This can be very difficult to clean and may require a service call to have the old insulation removed and replaced with new insulation in that section.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Ice frozen together
you can adjust the amount of water by popping the front white cover off the icemaker and adjusting a screw . depending on the model the screw will be a flat head on the side of the icemaker or a phillips screw on the front of the icemaker.
Aug 17, 2008 | Viking VCSB423 Side by Side Refrigerator
GE PDS20MBS
well it didnt get into the compressor area, but it definalty spilled in to evaporatr area, and landed on defrost heater. so yea your smelling boiled spoiled milk!!!mmmmm!!!! you would have to rermove back panel of freezer compartment to fully see the extent of spillage, as far aswhat got under refirig into drain pan, you can problably pull unit forward and remove back panel look into pan for spillage.
compressor would'nt be affected
Mar 05, 2008 | GE PDS20MBS Bottom Freezer Refrigerator
Bad smell from vent at back of fridge but able to remove back panel
if you cant remove it then wash it unplug the refrigerator from ac outllet first then remove the carton cover in the back and you gona see the pan were the water is temporaly storege with a garden hose washing the pan and then clean the floor use or news paper around the refrigy is helpfull the water or so in the pan is evaporated with the hot of the compresor sistem that water come frome the freeser compartment....good luck and rate me
Jan 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
127 people viewed this question
Top Viking Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
