Question about NorStar Lands Phones
Disassembling speaker Jamo 555
How should the speaker be disassembled from the speaker front on a Jamo Power 555 speaker. Is it glued to the front or??
cammedic
  • 667 Answers
SOURCE: tamron 28-300mm lens disassembly help
Both, But start at the rear to remove the electronics and the outer barrels. Remove any rubber grip to expose 'hidden screws'. I would mark everything or document with pictures during disassembly.
Posted on Jan 29, 2008
Hollyecho
  • 313 Answers
SOURCE: HP nc8000 LAPTOP DISASSEMBLY ETC....
I would try a new power adaptor cord 1st, they go bad alot and I have been on calls to soder the DC power socket many times, when it was simply a power cord problem.
If a new cord does not work the assembly manual can be downloaded from HP at this address:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00803690/c00803690.pdf
Posted on Apr 02, 2008
SOURCE: Z2300 satellite disassemble
1. Remove the black face screen. 2. The 4 holes on the satellite that hold the face screen on have a rubber stopper in each.  Pop those out with a screw driver.  There are now 4 screws to take out. 3. The front silver face plate is now only held on by glue.  Take a hair drier around the edges to soften the glue, then carefully pry the front face plate off, being careful not to damage it (I pried it from the bottom so any damage wouldn't be noticed).
Note: the 3 screws on the bottom have nothing to do with removing the face plate.
Posted on Nov 15, 2008
SOURCE: Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Posted on Jan 03, 2009
SOURCE: Bose COMPANION 2 Speaker case disassembly?
yes..the only solution is to pop the front panel with screwdriver...to do this more efficiently (without breaking the front panel) ...first insert the thin screwdriver in the gap in front lanel on side wall...and rotate the screw driver 90 degree..this will pop that side....repeat it on other sides too...i did it last night only.....
my problem was that when i dropped the speaker....its magnet fell down...and its no longer working...i am trying to find another broken bose speaker to replace mine...from e bay,,but no luck till now :(
Posted on Jan 26, 2009
Open jamo speakers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Sep 20, 2015 | Jamo S606 Main / Stereo Speaker
Disassembly instructions
A lot of those are sealed units. They are either glued or heated shut. If you don't see any screw holes then you have to decide if you want to use force or a saw to open then case.
Apr 17, 2015 | Cambridge Soundworks Audio Players &...
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Apr 30, 2013 | Jamo SUB 250 Subwoofer
Disassemble Toshiba 65H80 tv
No, cabinet is glued and screwed---entire front screen can be removed and the mirror inside also(be very careful with that) as they are the two things that get damaged most when transporting a set.
Moving a long ways or just across town?
Apr 22, 2012 | Toshiba 65H80 65" Rear Projection...
What batteries to put in the jamo i300 remote control
Remote Control Battery Replacement
To replace the battery, remove the two screws on back of the
remote and disassemble. It is a "Button" type battery not sure what the number is but look at the battery and find the number on it and replace it with the same style battery
To download a free owners manual go to this website
http://www.jamo.com/na-en/support/owners-manuals/
Jan 14, 2011 | Jamo I300 Docking Station
How do you disassembly right side headset to fix faulty connection
The headphone unit is sealed and cannot be accessed via the padded ear pads. You have to prise open the outer headphone cover which breaks off 4 internal attachment points (which can be re glued for re assembly). Be careful on the Left hearphone as it contains a complex electronic circuit board.
Aug 01, 2009 | Jabra C820s Headphones
Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Mar 15, 2009 | Jamo SW400E Speaker
How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Oct 27, 2008 | Logitech Z-340 Computer Speakers
No Power (LED off) in the Altec Lansing VS4121
There is no way to open the satellite speaker without destroying it. I tried and found that the whole thing was glued together. Mine is now destroyed
Apr 15, 2008 | Altec Lansing VS4121 Speaker
Speakers
Unfortunately, these cases were glued together and put in place by a series of plastic pins and tabs not meant to be removed. There is no safe or healthy way of opening the case without causing some serious damage to the pins holding the inside speaker in place, plus the lip inside the case itself will break (not unglue). If you are handy with manual tools, you can use a small spatula and start prying off from between the case and the front cover at the the center of the speakers and go around it. You will hear the plastic and pins breaking, but if you take your time and be patient the cover and case will stay in shape. I will post a video on youtube on how to do this
Dec 06, 2007 | Bose 100 Speaker
Lands Phones Logo
32 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
