Question about Yamaha DTX-MULTI 12 DRUM PAD
Factory settings 4 th patch not working.i cant set the voice all the u200 banks.can u help me?
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Why is there no sound output?
Hi, I am answering this generically, because there are a few things that can cause this on a lot of keyboards.
  1. Make sure there are no headphones connected. I have removed headphones and the 3.5mm plug comes out leaving the adaptor, this still cuts the speakers.
  2. Sometimes the switch on the headphone socket does not make properly, work the headphone jack in and out a few times.
  3. Local MIDI should be set to ON, if you cannot find this, as it is often buried in some deep menu, link MIDI out to MIDI in with a cable.
  4. Do a reset, be careful as some restore factory defaults and you will lose user presets, so back up, MIDI dump first, others allow resets that do not affect the voices.
  5. connect to your usual software (sequencer, patch librarian, etc) and see if the keyboard has been muted, volume set to zero etc.
  6. Is the volume knob turned up?
All the best, Chris the fader.
Jun 27, 2015 | Music
No sound on my SY77 yamaha synthesizer
1) Turn the power on.
2) While pressing the [VOICE] button, press and hold the [BANK D] button, then the [8] button. The SY77 will run the INITIAL TEST routine and display the Test Program Menu.
3) Press the [COPY] button. The SY77 will execute Test 48 'Factory Settings', automatically exit the test mode, and then return to play mode.
Mar 31, 2013 | Music
Yamaha MM6 Factory reset?
My Yamaha MM6 Synth is showing blank (white) screen when switched on. Keyboard sounds and banks are working. Everything looks nice but not showing any details on screen. Any help.....
May 20, 2012 | Yamaha MM6 61 Key Synthesizer
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
Hello there how can i reset my korg kaossilator pro please help i cant get it back to factory settings
press knob 1 and 2 and rec at the same time , then power on , then knob bank D , power off and on ,,,,, ready
Greetings Gerrie ( Holland )
Jan 10, 2011 | Korg Kaossilator Pro Tabletop Synthesizer
Como resetar o gfx8
zoom GFX-8:
The All Initialize/Factory Recall function is a special function
that lets you reset the GFX-8 to the condition in which it was originally shipped. When All Initialize is performed, all settings of the unit including all user group patches are returned to the default condition. Factory Recall can be used to reset only specific user group patches group to the default settings.
1. Turn power to the GFX-8 on while keeping the STORE key depressed.The display shows "ALL-INIT".
• To perform All Initialize, Continue with the next step.
• To perform Factory Recall, Use the BANK UP/DOWN foot switch and foot switches 1 - 4 to select the patch (from a user group) that you want to return to the factory default condition.
2. Press the STORE key once more.
All Initialize or Factory Recall is carried out.
If All Initialize was carried out,
the unit automatically returns to the play mode.
Note that when All Initialize is executed,
the contents of all patches stored by the user will be overwritten (erased).
When wishing to cancel All Initialize/Factory Recall,
press the EDIT/CANCEL key before step 2.
source: ZOOM GFX-8 User Manual.
Oct 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Only the piano sound works on my D-20. If i press a key in any other voice or instrument it just makes a high pitch sound and freezes up. And on the ''B'' bank its all organ sounds.
We can't possibly guess at what brand a D20 might be,,, HOWEVER let's guess that it is some kind of synth.
I would "guess" that you problem might be that the ionternal memory battery has depleted and the settings and sounds are all lost.
First thing would to be replace the battery. Next the settings need to be restored. SOME instruments have a sequence of buttons to hold while powering on to restore factory settings. Others require you to load data from an external source via MIDI or other method.
Feb 12, 2010 | Music
RC-50: Importing wav. files from computer to loop station.
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem. So , here it is . Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.) now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
Jan 19, 2009 | Boss Rc 50
Yamaha DTX-MULTI 12 DRUM PAD Logo
21 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
