Question about Canon imageCLASS Office Equipment & Supplies
Light darkness problem and print speed very slow
S h f p u c what meaning and function
Posted on Dec 27, 2013
Why are my pictures so dark?
Your ISO was to high or to low , I cant see your pictures to tell, but darkness means you diidnt let enough light in the lens set your appuatue to a small number and slow down your shutter speed. It will help preveiw your pictures before you print . Download Picasa for free and fix your pictures its easy. Goodluck Ozout!
Jul 28, 2014 | Nikon D5100 Digital Camera
Extremely slow printing
The printer is an inkjet printer. Inkjet printers are slow printers compared to laser printers.
Also the print speed depends on the size of the document printed.
If it is a large photo or file, it will take longer than small notepad file.
Speed also depends on coverage. A page with a lot of it covered in ink, will take longer than a page which is only coverd in ink on a small part.
Also the print speed depends on computer memory and USB cable. Fast cable and a lot of memory mean fast transmission of data to the printer.
Slow cable and small amount of memory (512Mb, or 256Mb or less) mean slow transmission of data to printer
Sep 17, 2010 | HP Deskjet D4260 Printer
HOW DO I SPEED UP MY PRINTER ON A MFC BROTHER 240 C
The only speed selection is when you select print quality, draft is fastest, and selecting best will slow the printer down to snail speed.
Oct 02, 2009 | Brother Multi-Function Center MFC-240C...
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
No print /No error message
First, you need to make sure the ribbon and labels are loaded correctly. Follow the diagrams on the inside of the door. Once this is done, check the print speed and darkness from the front panel. If you have a high print speed and a low darkness, depending on the media you are using, it may not show the print. Try either slowing the print speed down or raising the darkness.
Aug 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Print speed too slow
the speed may be sent by software.
Check if the speed instruction isn't in your code?
Jun 18, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Label Printer
Do you know the print speed that you are using? I would slow it down to about 7 ips and adjust the Darkness until you are happy. Some companies want all this speed and the machine cannot do a good job at high speeds (10 ips). If you are not able to over-ride their speed, call them. It will increase your print quality a great deal.
The print speed is the second setting on the menu. Don't forget to save the settings when you are finished (use "Permanent"). Good luck!
May 29, 2009 | Zebra S4M Thermal Label Printer
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Blurry or dark pictures in low light
Low light= slow shutter speed = camera shake
Use a tripod
Nov 04, 2007 | Kodak EasyShare Z740 Digital Camera
Slower printing speed
Multiple sheet feeding in any printer can mean many things. Paper roller blockages and jams, wrong paper for printer, too much paper in. Make sure you check right down the back and inside the unit for anh small blocks. This can then cause errors in the printer itself. As it is now printing but slow, the paer issue could be resoved but you may now have driver errors or pc issues. Are you getting any flashing LED lights. Have you checked to see if device is showing errors or functioning correctly. Go to start menu, control panel, performance/main, system, devices, scroll down to your printer, are there any yellow exclamations? Does it say it is working ok?
Aug 10, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
old marine
old marine
