Hotpoint wmd960 When the washing machine is turned on the display shows F:09 how can this be fixed?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
F09 EElectronic module configuration error Washing machine controller EEPROM is either not programmed or is not functioning
  • Check EEPROM
Posted on Dec 27, 2013
COXY
  • 76 Answers
SOURCE: HOTPOINT WT940P
Lower the outlet hose into a low bowl, if water flows then you need a new pump cost around 20 pound to buy, If no water comes out the you have a blockage somewhere.
Posted on Nov 30, 2007
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
barkencoa
  • 3463 Answers
SOURCE: access to the sump of WMD960 Hotpoint washing machine
There is a lower removable cover at rear of washer,remove this, locate and remove large black hose fastened to drum, locate and remove filter inside hose to clean.
Thanks.
Posted on Aug 30, 2009
  • 662 Answers
SOURCE: hotpoint wf865 problem
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Pl rate me nice if this solution helped!
Posted on Jun 08, 2010
Hotpoint wmd960
have you tried leaving the appliance unplugged for 30-60 minutes to reset the control board?
Apr 06, 2014 | Washing Machines
Hotpoint WMD960 F18 error code
I had the F18 fault.Nothing much worked except drain pump.
Simple solution for me was:
1)disconnect power 2)take off top of machine(2screws at rear) 3)locate the connector which fits on the rear of the main led display panel.4) Pull it off, squirt switch cleaner and replace with plenty of wiggling! 5) Put it back together and start washing !
Steve Brighton
Feb 24, 2012 | Hotpoint Washing Machines
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
Jan 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
Washing mashine shows door not locked
There will be a retaining band on the inside lip of door seal, on the front of the cabinet.
Insert a small screwdriver or similar into the lip of the door seal, there you should see the band, prise it off, and then pull the seal of the front of the cabinet.
Reassemble in reverse order.
Thankyou.
Jan 13, 2010 | Hotpoint Washing Machines
Access to the sump of WMD960 Hotpoint washing machine
Thanks.
Aug 29, 2009 | Hotpoint Aquarius WD640 Front Load...
I need a user manual for hotpoint washing machine wmd960 (8kg ultima)
go to hotpoint website, then support and you can download all manuals there
Aug 27, 2009 | Washing Machines
Wd860
setup error [check eeprom]. Call an engineer as you will have a 5 years parts cover
Jul 03, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
