Sony PlayStation 2  Console
Problem for Sony PlayStation 2 (PS2) Console
Ps2 memory card
By lofatmat on Oct 17, 2007
error loading comes up when i put memory card in
Clarification Request
Posted by y_test7 on Jun 04, 2008
y_test7 y_test7
Same Problem
Mar 17, 2009
-   It wont read the memory card data.-   Guest
Mar 14, 2009
-   Yeah, my ps2 memory cards are saying that there is not sufficiant space on the card, and that my ps1 memory card is unformatted, then it says "format now?" and if i press yes it says "unformattable."
This is really bothering me. :(-   Guest
Jan 30, 2009
-   ****,most of my data is corrupted for no reason! -   Guest
Jan 04, 2009
-   i hade an ps2 and it wont woork-   Guest
Dec 25, 2008
-   my ps2 memory card is in my play station now and every time i put in a game it says it does not have enough space and every time i go to browser i cant see my memory card can i have some help here?-   Guest
Best Solution
posted on Nov 25, 2008
Very Helpful)
diene_chan
Rank: Apprentice
Rating: 98%, 7 votes
how to fix a corrupted memory card for ps2 (ffxii file)
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Feb 26, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have an another problem. my memory card started to show unformatted device, format it ? i press yes, and it fails. what should i do to make it work
Solution #3
posted on May 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
How do you get rid of Corrupeted data of your memory card???
Solution #4
posted on Oct 18, 2007
Helpful)
Cerfer39
Rank: Guru  Sony Expert
Rating: 87%, 1164 votes
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #5
posted on Feb 11, 2008
Helpful)
bsarchi
Rank: Apprentice
Rating: 89%, 5 votes
the fact is your memory card is corrupted, same thing happens in flash disc which reads about a half full of MB but literally it has no data inside.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #6
posted on Nov 12, 2008
Somewhat Helpful)
josiah714
Rank: Apprentice
Rating: 75%, 2 votes
it always says load failed curruped data
Was this helpful?
Yes
No
Solution #7
posted on Jun 04, 2008
Somewhat Helpful)
y_test7
Rank: Apprentice
Rating: 75%, 1 votes
y_test7 solution
Was this helpful?
Yes
No
Solution #8
posted on Nov 07, 2009
Not Rated)
salilmhalas
Rank: Apprentice
Rating: 0%, 0 votes
when i insert a need for speed dvd in my playstation 2 error message appears ' please insert a playstation or playstation format disc' my ps2 series is 30003
Was this helpful?
Yes
No
Solution #9
posted on Oct 13, 2009
Not Rated)
hey hey619
Rank: Apprentice
Rating: 0%, 0 votes
i was playing NCAA 2005 and my game froze, so i was forced to press reset. i restarted the game and it just shows a red information box with nothing in it. What do i do. I HAD ALOT OF DYNASTYS AND PLAYERS MADE!!!!!!!! NOT TO MENTION A SCHOOL TEAM!!!!!! if i don't put in the memory card the game will load up fine. and i can play it normally. But i cant save or load anything on my memory card!!!!!!!!!
Was this helpful?
Yes
No
Solution #10
posted on Aug 07, 2009
Not Rated)
lailaha
Rank: Master
Rating: 80%, 25 votes
Try this link . . . http://www.Sony.com/PlayStation2PS2Consol
To find your best solution.
Was this helpful?
Yes
No
Solution #11
posted on Aug 04, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Inside the memory slot of the ps2 you will see a series of gold metal bands. They each should be slightly bowed above the plastic to contact the memory card. Often one or two are flat and miss contact. Take off cover and gently using a needle lift up these bands slightly. This should fix problem.
Solution #12
posted on Feb 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
help me fix the memory card of ps2
Popular Solutions for Sony PlayStation 2 Console
Questions and Unsolved Problems for Sony PlayStation 2 Console
Do you recommend Sony PlayStation 2 (PS2) Console?
Answer
Answer
I just bought Guitar Hero 5 and it won't play. Megatrom games said I need to get my machine serviced... (More)
Answer
my sony play station switch on and off at the same time what is going on??
Answer
My PS2 starts scratching disk in lined circular motion.I suspect the Lazer Ribbon Cable's work since... (More)
Answer
konsole schaltet beim spielen ab.eine zeitlang kann ich spielen ohne probleme dann... (More)
26 Other Users Have The Same Problem - Continued
Comment by bdog3895, posted on Dec 23, 2008
what do u do when you clean your memory card and the ports and there is still a problem
Comment by Guest, posted on Dec 20, 2008
i have the same problem pls help
Comment by Guest, posted on Nov 27, 2008
when i turn the ps2 on to play the games it says memory card error
Comment by hironakamura, posted on Nov 24, 2008
my memory card can't save new cd and i have a corroupt data
Comment by Sexy_Man987, posted on Nov 22, 2008
my memory card reads in the ps2 console, but it just won't let me save anything and I've lost all my memory I had on there. Can you help me?
Comment by Guest, posted on Nov 22, 2008
i was playing resident evil4 and after i was done saving the game every thing
was gone.so please help me out.
Comment by slimslizzle, posted on Oct 01, 2008
For Tiger woods 07 i load the game and then it says. Load failed Save game data on memory card (PS2) in memory card slot 1 appears to be corrupt.
Comment by jay 34, posted on Sep 28, 2008
i saved my games on my memory card but when one day everything was gone
Comment by Guest, posted on Sep 24, 2008
when i was trying to play my inuyasha secret of the cursed masked or my naruto ultimate ninja 2. it said put in a memory card i already had my memory card in there. so plz help me out
Comment by s7854692, posted on Sep 23, 2008
i dropped my ps2 now my memory card cant load my games in slot one
Comment by rfpajaro2005, posted on Aug 27, 2008
when i try to save a game on my memory card it said to insert a memory card what can i do?
Comment by jordan10, posted on Aug 21, 2008
when i play madden my it says error memory card has been removed
Comment by bluesmurf987, posted on Aug 16, 2008
When I am loading my DDR game, an error message comes up saying I have corrupt data. It's a sony memory card. It seems I've lost all the memory on my card. Will I be able to have this fixed?
Comment by spyscouter, posted on Jul 22, 2008
For guitar hero II, it will say, error loading, corrupted file.
How do I fix this.
Also, on my memory card, it says guitar hero III save which is right except on the program (guitar hero III) it doesn't detect this.
Comment by Guest, posted on Jul 14, 2008
turned on my ps2 to play need for speed most wanted an error came up and said load failed memory card is corrupt.Is there any way to get the game back
Comment by kadizzy, posted on Apr 05, 2008
my i wuz playin madden 08 for my ps2 then boom it happened it said i have no more room or sumtin then when i cleared room it still said i have no room
then i bought another meomry card it said the same thing
Comment by uestg, posted on Feb 13, 2008
wuz playing madden 07 memory card still in it said memory card was replaced or removed and i blew in it and cleaned the ps2 but nothing
Comment by Guest, posted on Jan 07, 2008
it says no memory in slot when card is in. how to fix?
Comment by Guest, posted on Dec 29, 2007
I was playing Madden 08 and it says memory card has been removed or replaced so i pulled it out and blew into it and reinserted it but it said it again
so turned off the system and went into the browser it showed the memory card in the slot but when i went into it it said no data and that i had only 162 kb of memory left. I cleaned the memory card with a Q tip but with no cleaner and it still didn't work
it does this in both slots what should i do?
Comment by whatever9001, posted on Dec 28, 2007
lost all memory after playing a game.
Comment by Guest, posted on Dec 16, 2007
When i turn on my ps2 to play madden it says error checking for memory card. How do I fix this problem?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
