Question about Hotpoint WMA54 Front Load Washer
Loud niose coming from my machine when spinning
My Hot piont WMA54 washing machine is making a terrible clattering niose when the drum is turning. I have searched for objects but have not found anything.
  • poobarroo May 22, 2009
    Hello thanks for the suggestions. It was in fact a bra wire caught between the two drums in order to access it there was a lot of dimantling to do as black clips in mentioned in the bra wire caught problem were not there. It took us four hours to dismantle and repair!
    Sergeant:
  • 187 Answers
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
When spinning it makes a very loud noise, i'm worried its dry bearings, it seems a big job to change and expensive? is that right?
I concur with your initial diagnosis, and would agree that it is a fairly substanial repair to carry out.
It involves a complete strip down of washer, nand removeal of drum .
Not a job to undertake unless you feel competent to do so.
As for cost, it is quite an expensive repair to carry out, as it could involve having to replace the drum shaft if it is worn.
Jan 10, 2011 | Hotpoint WMA54 Front Load Washer
LOUD CLATTERING NOISE DURING LAST MINUTE OF FINAL SPIN CYCLE
the loud clattering noise you hear is the main bearing it needs replaced.the main reason for the repair men doing a runner is its not an easy job and takes time and know how.if i was you i would get some estimates on this job,i would guess they will be high because no one wants to do it.Would you not consider a new machine???????anyway good luck.adrian,,,,
Jul 09, 2010 | GE Profile WPRE6100G Top Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
Loud rattling sound on spin
Dear customer,                                  We request u to do the following checks..
  1. Balance the load
For details on how to check them plz refer to the follwing link  http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Washing Machines
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Would not dry clothes to original dryness. Now drum is making a whinging noise at the drum spin as though its catching on something every time it rotates. Also made a very loud clattering noise as it...
I had this same problem. The drum spins on two small wheel which with the help of the drum belt support the drum. The wheels or their brackets may be broken and need to be replaced. These are accessable by taking the back off the dryer. Best to take the old/broken ones in to insure you get the exact replacement.
May 01, 2008 | Washing Machines
Drive belt and noises.
your drum shaft is broken this is making the pulley wobble causing the belt to come off and it will also explain the noise. This is a very expensive job sometimes requiring the complete tub to be changed might be time for a new machine
Jul 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Hotpoint WMA54 Front Load Washer Logo
211 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
