Question about Grob 4V-36 - 36" Throat Band Saw
How to put together a drive shaft on a Grob 4V-36 verticle band saww
Need to re-assemble the drive shaft assembly for the saw.
    Problem Solver:
  • 9 Answers
Here are a couple of links than might help: http://industrialmanuals.com/grob-4v36-band-manual-grob-series-manual-p-171.php
http://industrialmanuals.com/grob-operators-instruction-series-band-machine-manual-p-998.php
I included the 24" as they are mostly the same in design. One is just, well, generally bigger. I imagine with and exploded parts view you should be able to figure it out
Posted on Jun 25, 2014
The guide assembly on my 14" band saw will not stay peralell with the blade as it goes from the top of its travel to the bottom. it goes right to left going up and reverse going down the blade . the o
Sounds like something's bent. You might need some replacement parts. 14" band saws, regardless of brand, are generally made with Chinese parts that are knockoff Delta-Rockwell parts from many years ago. Grizzly sells most of these parts at reasonable prices. Check the exploded views of their saws to see if the parts match. Craftsman parts are expensive, even though they're the same part.
Mar 30, 2014 | Carter Products Rikon 14" Sears 14"...
How to put together the drive shaft assembly on a Grob 4V - 36 vertical band saw
I suggest you to check the operators manual. If in case you don't have the manual, contact Grob's technical assistance or you can get a manual available online. I got old manuals from bandsawmanuals.com but they don't have available manual for 4v-36 . By the way, I like the solid build saws from Grob, what's your usual cutting workload? I have 7x12 band saw with a Haltbar band saw blade from sawblade.com ,I cut structural steel, channel, angle, tube, plate, pipe, round bar,
Dec 27, 2013 | Grob 4V-36 - 36" Throat Band Saw
My Black Bull MBS45 bandsaw has a poor assembly manual, all was finally put together, but the pulley shroud fits way too loose and no other parts are left to make it a more secure fit. Is there a better...
Black bull doesn't have customer service? I've heard that there are lots of problems with blade alignment on that band saw. I have Trajan 712 band saw and it was easy to install it. Read this thing from
google. http://www.google.com/patents/US6739231
Feb 01, 2013 | Black Bull MBS45 4-1/2-Inch Metal Cutting...
Manual delta double swing and seesaw
Put bolt "A" into hole "B", repeat until complete.
Jun 27, 2012 | Saws
How to take apart the gear box on a milwaukee deep cut band saw 6230n
unplug tool, remove the handle assembly making note of the wiring, turn the tool over and remove the rear pulley under that you will find 2 torx drive screws remove them and then gently tap the housing to start to remove the gear assembly. remove the 4 bolts holding the gearcase to the motor housing and pull apart, when apart you can finish tapping and the lower gear along with the top one will "jump out" Let me know if you still have any problems
Jan 24, 2011 | Milwaukee Tool Milwaukee 6230N Deep Cut...
I would like to know if the wheel bearing is in the shaft or the hub?
The Constant Velocity (CV) joints are located on the inner and outer edges of the axle shaft. The axle shaft runs through the hub and bearing in the spindle.
Jun 16, 2010 | 1999 Daewoo Nubira
HOW DO U GO ABOUT PUTTING IN A HEATER CORE. NEED
1. drain coolant
2.remove instrument panel
3. for 5.4 (4v) if equiped,remove junction splash shield
  1. For 5.4L (4V), if quipped, remove junction block bracket.
  2. Clamp inlet and outlet heater hoses.
  3. Disconnect heater hose from heater core by gently pressing it toward heater core.
  4. Remove A/C plenum demister adapter.
  5. Disconnect vacuum line.
  6. Remove 13 plenum chamber top screws.
  7. Remove blend door assembly from case.
  8. Remove heater core.
To Install:
NOTE: If needed, clean and lubricate coolant hoses with plain water.
  1. Install heater core.
  2. Install blend door assembly to case.
  3. Install 13 plenum chamber top screws.
  4. Connect vacuum line.
  5. Install A/C plenum demister adapter.
  6. Connect heater hose to heater core.
  7. Release all clamps from inlet and outlet heater hoses.
  8. For 5.4L (4V), if quipped, install junction block bracket.
  9. For 5.4L (4V), if quipped, connect starter relay cable.
  10. For 5.4L (4V), if quipped, install junction splash shield.
  11. Install instrument panel.
  12. Refill engine coolant.
I hope this helps you
Nov 12, 2009 | 2000 Ford Expedition
How to replace main shaft bearing
Almost all of the Skil table saws are the same setup when it comes to the motor and drive assembly. Remove your blade before servicing. You will need an arbor press, bearing seperator/puller and drill/driver bits (torx or philip depending on model) plus some adjustable ring pliers to accomplish this repair.
First thing you have to do is remove the motor from the saw. Place the saw on its wide side and adjust the motor with the height adjustment wheel so as to access the hex screws holding the motor to the rack.
Next, before removing the motor you need to remove the motor cord from the switch. Flip the table saw upside down flat on its table. Remove the switch cover and disconnect the black and white wire from the switch marking their position or noting the other wires from the cords position and the relation to the motor wires. Now you can undo the hex screws to release the motor.
Once your motor is released you can remove the spindle shaft by removing the 3 screws from the bearing housing. You can pry the assembly off with a couple of screwdrivers or by using a soft hammer and tapping the edges to remove.
Once removed you will have to remove the gear before you can get to the bearing. Use a bearing seperator/puller to pull the gear off the shaft. Once the gear is off you need to remove the woodruff key before removing the bearing. After the woodruff key is out you can remove the c-clip that holds the bearing to the shaft. Now you can use an arbor press to press the shaft out of the bearing.
Replace your bearing and put it back together. Any questions please post back.
Oct 12, 2009 | Skil Saws
Upper wheel adjustment flange fell into assembly
K just went to Skiltools.com and the parts explosion I wanted is not available online. You can send an email to customer service or call them. You might also try the store where you bought this tool. Sorry I couldn't help more
Feb 19, 2009 | Skil 3385-01-RT Factory-Reconditioned 9"...
Grob 4V-36 - 36" Throat Band Saw Logo
61 people viewed this question
Top Grob Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Grob Saw Expert? Answer questions, earn points and help others
