Question about Encore ENH905-NWY (ENH905NWY)
My two computers cannot pass through my broadband provider (through the switching hub) at the same time.
I have two computers connected to my Encore ENH905-NWY (5 port) switching hub. However, only one computer can access my broadband service provider. How do I set my network connection so my two computers can access the internet with the one broadband account? Thanks for your help. Terry
  • 4 Answers
>use router like tplink 740 N whether your service provider allow u or not one or more users at the same time router is a best choice for internet distribution.do not required switch or hub it contain 4 lan ports.
>your internet wire pluged at wan port and attach four pc through lan ports
at the router all pcs connected & works at same time and also enjoy wifi,
Regards Massam
www.bestfashionstyle.net
Posted on Apr 25, 2012
  • 256 Answers
It sounds like you have a switch hub attached to a modem and two computers attaced to the hub. At first glance, this should work but does not. The modem will only recognise the first computer to communicate with it and hold that connection. You need a router to talk to the modem first and the computers to talk to the router. The router acts like a computer to the modem ut in actuallity it just passes the communications from the computers to the modem and from the modem to the proper computer in turn.
Posted on May 28, 2009
That is not possible for an single isp connection you can only connect one computer at a time and hub is basically a repeater that is it simply repeats the packets it receives from one input out the others.
I have a broadband connection and have 2 computers.i want to split the connection so that both machine can use the internet at the same time..should i use a switch or use a router..am confused..i wanted to...
Hi
when you use the broadband connection you must use router to split the connection .
so I suggest you use broadband router like DIR-120 Or DIR-330 for wireless..
you can choose what you need from here
Apr 24, 2011 | D-Link Computers & Internet
Why i cannot connect broadband connection through switch more than one computer at same time? But only one computer can connect.
Internet through your broadband connection is normally setup for single user.
If you need to use multiple systems to be connected to internet then you need NAT (Network Address Translation) to be enabled.
But unfortunately the D-Link DES-1008D doesnt support that.
Dec 02, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Can use only one computer at a time. Why i cannot use 4,5 computer same time?
I think you are trying to access internet through broadband.
Normally the Broadband is configured for a single user, if you want to use multiple computers to a single connection then you need to use a technology called NAT ( Network Address Translation).
This technology comes with all the Layer3 devices (Routers).
You can purchase a NAT capable device and you can use 4-5 computers through a single connection to reach out internet.
Dec 02, 2010 | Computers & Internet
I have 10 computer.i want to connect it to the
u have to connect all the PCs to the HUB first...then connect the Hub to the Router(broadband modem)...u need to first establish a connection to the internet serivce provider by entering the necessary IP address/subnet mask/gateway address etc in each PC...
Note each PC will have a different IP address
PC1 - 192.168.1.5
PC2 - 192.168.1.8 etc etc...not necessarly in the order mentioned above....
the rest of the settings will remain the same in all PCs
refer attached word doc
reg
pls let me know if this was helpful...leave a feedback...
Jun 16, 2010 | Linksys WRT120N Router
On my hub right, on broadband it's shows that it's red meaning that it's not working properly. can you tell me what's the problem please
Power-off the hub.
Power-on the hub.
Did the problem go away?
Call your Internet Service Provider, to check if they are supplying a broadband connection "into" your hub. If they are not, then they need to fix a problem at their end.
May 28, 2010 | Network Computing Devices (NSH800S/A)...
DES-1008D connectivity issues.
Is the modem a DSL or cable model?
Does the router have one ethernet port and a WAN port?
Normally the broadband modem is connected to the WAN port on the router and the ethernet port on the router is then connected to the hub/switch and the computers are then connected to the hub/switch.
The modem gets an unique IP address from your Internet Service Provider and then the router then issues Class "C" IP addresses to each computer that is connected to the switch/hub.
Jul 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
What do I need to conect my wireless encore router
you need to have a LAN card, but normally, all computers have built-in lan card provided its a new computer. make sure you also have a broadband connection
Apr 02, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
Both computers not able to connect to the internet
First see weather you have given a correct and diffrent ip address for both and the computer name should not be same and the check with the dns it shound be correct if you dont have any ask your service provider
if this all does not work check with the network cable it should be crimped striaght when connecting to a computer from switch and it should be crimped cross when you connect a modem to switch
and if you are not using a broadband via ethernet then you have to use a proxy
Apr 29, 2008 | Linksys 5-Port Ethernet Switch (SD205-UK)
NH1005
connect your broadband modem into hub. configure your broadband modem to PPPOE. then u can access internet in both pcs.
Mar 10, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Encore ENH905-NWY (ENH905NWY) Logo
233 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
