Question about ASUS P5M2-M Motherboard
Intrusion chassis how to solve
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Asus web site support download manual from them type in your board at that site ok
Posted on Jan 23, 2014
  • 9 Answers
SOURCE: Chassis Intrusion Lead
Go to this web site
http://dlsvr02.asus.com/pub/ASUS/mb/sock478/p4pe-x/e1474_p4pe-x_te.pdf
Posted on Dec 05, 2007
  • 13433 Answers
SOURCE: Chassis Intruded!
Hey,
Go into bios or cmos setup. when you turn the computer on it says what you need to press to get in there, look over the bios, look for chassis intrusion detection, turn it off, then go back to the main screen save and exit.
you won't have the problem anymore.
Thanks and good luck.
Ekse
Posted on May 05, 2009
map9966
  • 2351 Answers
SOURCE: chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
technical114
  • 1851 Answers
SOURCE: Chassis intrusion messagen
This means that either the case of the desktop is open or it is not closed properly. I don't know what kind of case you use so I can't be more specific. Try to close the case (open and close again) or check for an open side. If you are sure that the case is closed and still the alarm exists, there is a way to bypass that kind of alarm, but youhave to edit the bios settings.
In case of a problem or clarification or if you want to bypass the alarm from the bios, don't hesitate to post me a reply.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Apr 29, 2010
tecnomage201
  • 221 Answers
SOURCE: chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Posted on Jul 21, 2010
How to reset the case intrusion warning
Resetting the Chassis Intrusion Detector
  1. Enter system setup by pressing <F2> during the computer's start-up.
  1. Under the System Security tab, reset the Chassis Intrusion option by pressing the left- or right-arrow key to select Reset. Change the setting to Enabled, Enabled-Silent, or Disabled.
May 20, 2014 | Dell OptiPlex GX270 PC Desktop
J ai beaucoup de probleme avec mon desktop p4p800-mx chassis intruded
You have a problem with the Chassis Intrusion part, of the Asus P4P800-MX motherboard?
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800MX/#download
The Chassis Intrusion header is below the CMOS battery to the left.
It is in-between the two black SATA connectors.
It is a 4-pin header.
From -> LEFT to RIGHT pins are numbered 1, 2, 3, and 4.
Put a Jumper Cap on Pins 3 and 4, and bypass the Chassis Intrusion option.
In the -> OS box, click on the blue Down Arrow. Now click on Windows XP.
In the drop down list, click on the + sign to the left of Manual (5)
Version E1880 - P4P800-MX user's manual (English version) E1880
Click on the blue -> Global
Go to Page 35. (PDF file page. Manual page is 1-25)
Chassis intrusion connector (4-1 pin Chassis1)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 06, 2012 | ASUS P4P800-MX Motherboard
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
May 27, 2012 | Dell OptiPlex GX620n PC Desktop
Chassy intrusion error on asus motherboard
> chassis intrusion
There can be a sensor inside the case, that is "tripped" whenver the side-panel of the case is opened, i.e., somebody has removed the side-panel, in order to remove some components, e.g., RAM, or add-in adapter card. So, if it was a "thief" (an "intruder") that opened the case, to expose the "insides", check that nothing was stolen. But, if it was you that opened the case, then enter BIOS SETUP, and "clear" that "chassis intrusion" status.
Jun 26, 2011 | Computers & Internet
How can i disable chassis intrusion on p5kpl-am se board? the board don't have any intrusion switch...
For the chassis intrusion circuit to work, the chassis power supply must be connected to AC power. By default, on the motherboard the pin labeled chassis "signal" and "ground" are shorted with a jumper cap. You need to remove the jumper caps if you intend to use the chassis intrusion
hope this helps
Dec 07, 2010 | ASUS P5KPL-AM SE Motherboard
I am getting the fatal error chasis intruded error on every boot...motherboard model is p5sd2vm...rahul
Chassis intrusion can be disabled one of two ways.
First, Check your bios settings. There should be a security or PC health section where you can clear that error and disable the intrusion warning.
Second, there is likely a small switch near the chassis side when the side panel is removed. This is the chassis intrusion switch. It will likely lead to a 2 or 3-pin connection on the motherboard. this can be disconected without any ill effects.
Aug 13, 2010 | Computers & Internet
Chassis Intruded!
Hey,
Ekse
May 04, 2009 | ASUS P5V800-MX Motherboard
Chassis intrusion
Cheers!
Mike
Asus Board MOdel Number P4BGL (845 Mxl) is giving an error called Chasis opened or tampered.?
I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
" 9. anonobomber, 07-05-2002 09:51 read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check http://www.asus.com.tw for the manual pertaining to your motherboard"
Jan 21, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intrusion turned off and not detected
If you're refering to the chassis intrusion... (Which is what I'm assuming.)
There should be a switch in the case itself that release itself when you open the case. Make sure that it is properly placed and angled and that it is connected to the appropriate pins on the motherboard. (Often labeled "CH INTR" or something to that effect.)
There is also usually a function in the motherboard's BIOS that enables/disables the chassis intrusion alert. Check to make sure that the function is enabled in the BIOS. (Don't forget to save your settings!)
There may also be a jumper on the motherboard that enables/disables the chassis intrusion detection. (Although this is less common.) Check around for that if the other options aren't making themselves apparent to you.
Good luck with that. Hope I was on the right topic. :P
Cyryl
Nov 02, 2007 | Intrusion Intel PRO/1000 XT Server...
ASUS P5M2-M Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
