Question about Beko Washing Machines
Power switch dont know where the wires go
I have a 3 speed ceiling fan I wired the light but dont know how to connct wires for fan
If the fan only has 2 wires a blue and a white, blue goes to power supply white goes to neutral. Fan switch itself provides the 3 speeds.
Jul 03, 2014 | Westinghouse Electric Westinghouse...
NO power to pto craftsman gt 5000
could be a clutch switch look at sears parts online for the location
Apr 01, 2012 | Garden
How do I check the wiring harness on my 99 ford explorer, the power windows dont work, I replaced the gem and changed relays with my 2000 explorer to see if that would trouble shoot it but they were good...
First you need to do a physical inspection on the wire. You need to check loose connections or exposed conductors. You then have the option to remedy by refitting loose connections, covering the exposed conductors with electrical tape or replacing the wire.
It would be best to have a multi-tester or multimeter. This should include a continuity tester and a voltmeter. With the use of the continuity tester you can put probes at both ends of the wiring and listen if the meter would beep which mines the lines are not cure or breakage between the ends. A voltmeter is used to measure if you are getting voltage to the end or the wires or the terminals of the switch or the motor. Weak voltage may mean a weak battery or the wires are not connected securely at either end. No voltage at the end of the motor but power to the side of the switch where the wires go to the battery means a problem with the switch. Others use a test light which is like a continuity tester when it lights up.
It does looks like a wiring issue the way you described the problem but it is a good idea to test.
Jul 14, 2011 | Ford Explorer Cars & Trucks
Brake lights dont work, replaced switch, checked for power, power to switch, power to fuse, checked wiring to back end, all appears to be good, put power to white wire, no brake lights still, i need some...
You hit it on the nail, you have check every thing we would have checked here at my repair shop, it's going to be the turn signal switch, as you now the brake light circuit run's through it and more then likely your center top brake light works.Bad switch (turn signal).
Jul 07, 2010 | 1991 GMC Sierra
I DONT KNOW WHERE Tto pug in the power
Power Led?
hard drive Led wires?
If you are building a machine these areusually pluged directly into the motherboard.
the plugs are usually only compatible to their special sockets on the board. all you need to do is to examine the plug ends and look for sockets withsimilar shape and size as the plug.
Jan 05, 2010 | E-Machines eMachines Desktop PC
I have a second hand power antenna that i want to fit to a 1978 gemini with no power antenna but dont know how to wire it up it was three wires one white one yellow and one brown the white and brown are...
I used a 2 way switch in my explorer and had to raise and lower it manually- i dont know how to wire it to where it does it automatically but heck it worked
Jun 09, 2009 | Car Audio & Video
I dont know which wire in the memory to connect it to my after ma
The memory wire is usually the yellow wire in the harness - it goes to a constant 12v (battery) source. That's how the cd player remembers all of your presets. The red wire (the other power wire) is connected to a switched 12v source, so it only sees power when the key is on. That is why the cd player shuts off when you turn the key off.
Mar 27, 2009 | Pioneer DEH-1600 CD Player
Master power window switch
no but i alway do it like that the window that not working push button uut and jump power to different wire just quick toucht you dont whant to blow fuses it gonna go up cherrs pierre
Jun 29, 2008 | 1998 Chevrolet Malibu
Power button wiring help
Hello Chub, Your motherboard manual can be downloaded at this link: http://support.asus.com/download/download.aspx?SLanguage=en-us If you go to page 2-31 in the above manual the diagram should show you exactly where your front panel power switch connects to your motherboard. You want to connect it to the position marked below as ?ATX Power Switch?. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 15, 2007 | ASUS A8V Deluxe Motherboard
Washing Machines Logo
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
