Question about Gaggia Unica Bean To Cup Coffee Machine
Gaggia unica will not prime
When starting the machine I am requested to prime it. When priming it, only a little water comes out of the steam wand, and it stops after 10 seconds with a red exclamation mark. I therefore turn the steam knob returning me to the original situation where it asks to be primed. After trying to prime 3 times this way, all red signs starts flashing rapidly. I have descaled it with citric acid trying these 3 cycles of water priming for a week, but no help.
    New Friend:
Same problem and I FIX it!
The problem was the flow meter (turbine) which can cause two problems:
  1. like your, poor water from steam.
  2. the machine always ask to prime
The first one is caused by limestone that blocks or partially blocks water entering the flow meter (it has a very small hole)
The second one by limestone that block the flow meter rotor
For both:
  1. Remove the flow meter block (with the whole Black block containing the pipe coming from water tank). You have to lift the black block from the back and pull.
  2. Separate the flow meter from the black block
  3. Disconnect the In and the Out pipes.
  4. When you have the flow meter in your hand (only the white piece), open it turning it's top (clockwise may be)
  5. Using a tooth brush clean well inside parts (top, base, red-rotor)
  6. Using a paper clip clean well both holes (in and out)
  7. Clean the o-ring
  8. When reassembling the flow meter pay attention to the o-ring between the top and the base which must be well fitted into it's seat before close it (if not, some air may come in the water circuit and the pump will not work).
The In and the Out pipes must be at 90 degrees when closed.
Before reconnect pipes, blow with your mouth into the In hole. You should hear the rotor rotating very well.
Hope this help
Posted on Nov 30, 2015
3 Suggested Answers
SOURCE: Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Posted on Sep 17, 2007
EsWorld
  • 1618 Answers
SOURCE: Gaggia Coffee Classic Steam Valve Leaking - No Pressure!!
Yes it can be repaired if you have the parts, you will need the complete steam valve with the o-ring that connects to the boiler check the diagram below.
Posted on Aug 28, 2009
I have a Saeco Incanto classic, the low water light is on, tank is full, and I have steam coming from the steam wand.
try descaling the machine it could be that the water level switch is clogged with water calcium and not lifting when water is added, or it is defective and needs replacement. I hope this was helpful.
Oct 22, 2014 | Saeco Incanto Classic Espresso Machine
Gaggia Tebe group head seal replacement and priming
check with manufacturer FIXYA has never had one given to us to disassemble
Dec 30, 2017 | Gaggia Tebe Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Oct 21, 2009 | Gaggia Baby Espresso Machine
Gaggia won't prime
Put a cup under the steam wand and then open the steam valve while turning the pump on. Once you have pumped a few ounces of water out of the steam wand you can close the valve and it will start pushing water through the grouphead.
Michael Ventura Laguna Beach
Oct 11, 2009 | Gaggia Classic Espresso Machine
I have a Saeco Incanto RS Espresso Machine. The prime light is on, but the machine won't prime. Very little water of steam comes out of the wand.
You need to manually prime it using the priming bulb that came with it. Instructions are in the manual. Remove water tank. Fill priming bulb. Hold priming bulb on water inlet. They don't inter-connect, so just hold it on there as best you can. Turn the machine on, turn steam knob on, and gently, slowly squeeze the bulb to force water into the machine. It works best when the machine is cold, because you want to get liquid water in there, and not have it displaced by steam.
Jun 30, 2008 | Saeco Incanto Classic Espresso Machine
Gaggia Unica Bean To Cup Coffee Machine Logo
679 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
