Question about Canon Pixma MG5220 InkJet Printer
Open ink compartment
How do I open cartridge compartment
How do I open up the compartment on the Canon Pixma to install new ink cartridges?
Posted on Jan 17, 2014
I have forgotten how to move the ink cartridges into a position where they can be changed.
Turn on the printer. Open the top of the printer to expose the ink cartridge compartment. Hit the "Stop" button. This will cause the printer head to move so that one of the two ink cartridges move above the "No Ink" icon. Hit the "Stop" button again. It will move the other ink cartridge above the "No Ink" icon if it needs to be replaced. The printer head will move to the original position to the right.
Aug 29, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I forgot how to change the ink cartridge on my printer i dont rember where it is please help
If you go to the below link -
Canon MP530 manual
and look at pages 44 - 46 it shows you how to change the ink cartridges. Just bear in mind the page takes a while to load as its a 4mb pdf so it will just stay black for a while until it downloads.
Thx, if this solution helps please rate :)
Feb 03, 2011 | Canon PIXMA® MP530 All-In-One Printer
The color does not print anymore, only the black thank you, jacques los angeles
Printers usually have two separate ink cartridges. Depending on the cartridge that is over exerted in print jobs is depleted faster than the remaining one. Open the ink compartment to ascertain the ink models to make possible acquisition for replacement from retail. Ink acquisitions may require verification for the appropriate models and brands. Extracting the depleted ink cartridge as reference comparison at retail enables appropriate ink selections compatible with the printer.
Feb 02, 2011 | Lexmark Z615 InkJet Printer
How can i remove the cartridge?
  1. Open the ink compartment door.
  2. Press down the release of the latch that holds the ink in place. (see attached)
  3. Pull the cartridge strait out.
  4. Remove the yellow cap from the new cartridge.
  5. With label facing you install the new ink.
  6. Close the locking latch. You should hear a click.
  7. Close the door
Dec 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
HOW DO I CHNGE THE CARTIDGE.?
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
3. Open the control panel and cartridge compartment cover (it will click and remain open).
4. Pull the cartridge toward you and remove it.
3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
5. Close the cartridge compartment cover and control panel.
6. Press Start/Enter.
7. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
How to reset lexmark c540 toner low?
Hi there
Open the ink cartridge door above the paper output tray on your Lexmark printer.
Push the release tab behind the ink cartridge to remove it. Pull the cartridge straight out of the ink compartment.
Pull the protective tape off the bottom of the new ink cartridge. Insert the new cartridge into the compartment and press it back until it locks into the compartment.
Close the ink cartridge door. Push the arrow button on the keypad to select either "Standard" or "High Yield" based on the type of cartridge you installed. Press "Select" when the proper type displays.
Sep 19, 2010 | Lexmark C540N PROD SPECS TBD Printer
How do you open for ink replacement?
Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
  1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
  2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
  3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
Installing a new print cartridge Follow the steps below to install a print cartridge.
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
  2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
  3. Close the cartridge compartment cover and control panel.
  4. Press the Start/Enter button.
  5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
for more information follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
Where is the ink cartidge compartment??
just raise the top lid and the cartridges will come to the center and stop
Jun 03, 2009 | Dell 926 All-In-One InkJet Printer
How to change printer ink cartridge
This is fairly simple. first make sure you have the proper replacement cartradge. then open the frount of your printer. your cartridge compartment should slide to the middle. to open these compartment you should look at them they should have an arrow or some sort of instructions. remove the old cartridges, take the new cartridges and make sure the securtity tape has been removed from over the bottom. then place them in the proper slots, black/color. firmly push them in, and close the ink compartments and the frount of your printer. you should be ready to go! if these instructions were not helpful, you should refer to the printers user manual and lookup ink replacement. if you have no manual, then search for your printer type and model and check out the faqs.
I hope this information was helpful.
Aug 01, 2008 | HP Computers & Internet
Canon Pixma MG5220 InkJet Printer Logo
88 people viewed this question
old marine
old marine
