Question about Canon imageCLASS MF6590 Copier
How to print envelopes on canon mf6590
I am having trouble trying to print addresses onto an envelope from my printer. How do so?
  • Canon Master
  • 8,064 Answers
The way I do it to create in Word 2007 envelops. While a letter is still displayed look for Create button and select Create envelops. You select the dimensions of the envelop and the way it is fed. You will need to try a few times to be sure it comes out correctly.
Posted on Dec 28, 2013
  • 5 Answers
SOURCE: Trouble printing envelopes
Instead of Word 2000 use Corel Draw for printing invelope. Because there are too many options for placing your text at desired position.
Posted on Oct 01, 2007
  • 3 Answers
SOURCE: Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Posted on Jan 09, 2008
  • 39 Answers
SOURCE: CANNOT PRINT ENVELOPES
you can only print paper not envelope
Posted on Feb 09, 2008
rhoncruz
  • 134 Answers
SOURCE: How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Posted on Dec 01, 2008
efs_perpends
  • 1996 Answers
SOURCE: Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Posted on Apr 10, 2009
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
How to print address on envelope on canon mx892
Printing envelopes on Canon MX892: Remove paper from rear tray. Adjust gray width handlers to the size of your envelope. Insert a blank envelope in the rear feeder, with flap oriented on the back left side.
May 30, 2012 | Canon PIXMA MX310 All-In-One Printer
How do you print an address to an envelope? And can you only print #10 envelopes?
No, you can print on any envelope size. As far as addresses are concerned, you need to setup a template for the envelope size in your program. What program do you have for this function, do you have Microsoft Word or come other word processor like that?
Jul 11, 2011 | Canon Pixma MG8120 InkJet Printer
Printer will not print the address onto the envelopes, it just keeps flowing them through
the envelope size is not selected in the printer properties. check the settings in the print properties and select the paper type as envelope and size of the envelope.
Oct 01, 2010 | Pitney Bowes AddressRight DA300 Printer
Envelopes print crooked
A decent printer should print a #10 envelope without a problem. If this model won't do so, return it and get another printer. Suggest Epson or Canon -- AVOID HP printers.
Oct 10, 2017 | HP Laserjet CM2320nf All-In-One Color...
Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Note:
    Note:
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer keeps printing the same address on envelope
You need to restart the printer some times happens if the buffer gets full.
Dec 15, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Canon imageCLASS MF6590 Copier Logo
135 people viewed this question
old marine
old marine
