Question about IBM Lenovo ThinkPad X60 Laptop
Authentication problems Trying to connect to my wireless network
  • 1,511 Answers
You must have the Pass Code that came with the wireless modem/router. Usually it is on a label under the unit.
Posted on Jan 09, 2014
Authentication failed
Are you trying to connect to a wireless network ?
If so when asked for a password to authenticate yourself, you will need the correct password, otherwise authentication will fail and it will be impossible for you to connect to the network. That's without using the correct password of course. If you are the administrator of your network.
Connect to the router's or Wireless AP interface, there will be an IP address associated with the device (check the owners manual for the address) and type this into your browser to access the Web GUI, no from here you will have to find the wireless settings and make sure that WPA2 security is enabled and that the password you create fits the criteria that it asks.
Once you have done this go back to the computer you where originally trying to connect with and use the password that you just configured when it asks you.
If you are still unsure please ask me.
Apr 29, 2013 | Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Not connecting to the internet
Router ?
Problems authenticating a router in a computer is a common problem when installing a router or if your internet service gets disrupted. It is easy to solve and only requires a few steps to fix. A router forwards data from a computer to a computer network. The network can be between multiple computers, such as one would need in an office. The network can also, and more usually in households, used for connecting to the internet. Open "System Preferences" in the Applications folder in Finder. Open "Network" under "Internet and Wireless." Click "Advanced" and select "TCP/IP." Select "Renew DHCP License" and click ok. Attempt to connect to the internet. If the internet is still not connecting, restart the router and try the steps again. b> For non-Macs b> Open "Wireless Network Connection" from the wireless tab at the bottom of the screen. Select "Change Advanced Settings." Choose the "Wireless Networks" tab. Choose the wireless network you want to connect to and select the "Properties" button. Under the "Association" tab, make sure the Network Authentication has the proper security level chosen. Enter your network key if your security code is anything other than "Open" or "Shared." Select OK and try to connect. Go Back to "Wireless Networks" tab -> "Properties" and click on "Authentication" tab and un-select the "Enable authentication for the network" selection if the network key is still not authenticating the router. Select OK and try to connect.
Hope this helps.
Jan 14, 2013 | Computers & Internet
I have a 7 Inch Capacitive Touchscreen Ultra-Thin Tablet PC with HDMI Camera. I am trying to connect to the internet. I have an N300 Router. I keep getting 'authentication problem'. Any sugge
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 30, 2012 | Computers & Internet
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
That means you probably don't have the password or theAuthentication Type set correctly.
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
May 10, 2012 | Dell Computers & Internet
When trying to access my wireless network it tells me that it cant locate a certificate to log on to my wireless connection. What does that mean? I have two other children who received these netbooks and...
If u are using Win XP, try the folowing steps.
First, click on the wireless icon in your taskbar and under Related Tasks, choose Change advanced settings.
Click on the Wireless Networks tab and select your network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box.
Once unchecked that box and try to reconnect to the wireless network.
If you are using Win 7 Starter, Try teh following steps.
Click on Start and go to Control panel>Network & Internet>Network & Sharing Center.
On the left side u will find Manage wireless networks. Click on it.
Now select your network in the list. Click on Properties.
Dec 25, 2010 | Acer Aspire One PC Notebook
Netgear wireless router wgr614v7 not transmitting a signal anymore. everything seems fine but it's not pumping out the signal.
Dude try the following steps it will help,else let me know the exact problem
  1. Click Start > Connect To > Show all connections, and then double-click your wireless network.
  2. Click General > Properties.
  3. Click the Wireless Networks tab.
  4. Under Preferred Networks, click your home network and then click Properties.
  5. Click Authentication, then clear the Enable IEEE 802.1x authentication for this network check box. (If you cannot click the check box, then you are not using 802.1x authentication or wireless security.)
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
While trying to connect a pc to the WRT54G2 wireless broadband router,windows gives me the following message: ''windows cannot find the certificate to log on to the linksys network'.what is the problem...
On Windows XP
>>right click wireless connection icon >>view available wireless network >>click on change advance settings inte left(SP2) orAdvance(SP1) >>on top click on tab wireless network >>clear preffered networks >>Click on ADD below preffered network box >>Put in the details for the titles mentioned below Association(Tab) >Network Name (SSID) : put in your wireless network name >Data Encryption should be check >Network Authentication(Shared mode) should be unchecked >The key is provideded for me automatically uncheck it >put the network key and confirm it Authentication(Tab) >check Enable IEEE 802.1x >now uncheck Authenticate as Computer when computer info is available >now uncheck Authenticate as as guest when user or Computer when computer info is unavailable >uncheck Enable IEEE 802.1x >>click OK now it will start working enjoy
Sep 29, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Laptop says validating identity
Right click on wireless network connection and go to properties. From the Wireless Networks tab, choose your wireless network and then click Properties.
Click the Authentication tab. On the Authentication tab, Uncheck"Enable IEEE 802.1x authentication" for this network check box. and click oK.
Now reconnect to the wireless network and you will be able to connect to it.
IF you still face issue then please enable WPA encryption on the wireless router and that should work fine with both the laptops.
Rate it, if it helps.
Jun 27, 2009 | Belkin Computers & Internet
IBM Lenovo ThinkPad X60 Laptop Logo
24 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
