Question about Magimix 5100 Cuisine Systeme Food Processor
Magimix motor slow - Magimix 5100 Cuisine Systeme Food Processor
Hi my magimix 320xl won’t turn on the Handel clicks in ok so I’m not sure what the problem is it’s only been used a couple of times hope you can help me thank you Christine
Magimix is the best name in foods processors. They are very reliable with a direct drive motor. As I am sure you know that have a safety interlock, and this may be what is giving you the problem. The bowl has to be locked in place with the handle over the interlock button in the base. This is with the handle dead centre of the front of the machine. It won't work if you decide the handle would be better off at the side of the machine. Then the lid has to be locked in place with the lug in the slot in the top of the bowl. Only then will the machine operate.
If all that checks out, then you will need a service centre.
magimix service agent Google Search
The instruction manual is accessed from here
http://www.magimix.com/usa/page/Instructions-for-use
Dec 10, 2017 | Magimix Food Processors
How can I test the motor relay on a Magimix food processor?
Overloading may have caused a thermal protector buried in the motor windings to open in which case the motor will have to be replaced.
Jun 04, 2016 | Magimix 4100 Cuisine Systeme 1268 Cups...
Cleaning magimix handle
Magimix Food Processor and Bad Customer Service
fussfreeflavours.com/the-tale-of-the-magimix-and-bad-customer-service/
Jan 12, 2012 - Magimix food processor review - the exorbitant cost of replacement ...time to find out how to clean the internal part of my Magimix 5200 handle.
magimix compact clean handle Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your magimix compact clean handle question. Get free help, tips & support from top experts on magimix compact clean handle related issues.
Food processor - Magimix
www.magimix.uk.com/page/faq/Food-processor/CS-5200-XL/
Magimix UK : FAQ Frenquently asked questions - Food processor. ... direction until the locking tab engages the top of the bowl handle. ... Never exceed the quantities recommended for your food processor model in the instructions for use.
Amazon.co.uk: Customer Discussions: Food processor bowl to
Jan 01, 2016 | Magimix Food Processors
Even after replacing the fuse my magimix 2800 food processor won't come on what should I do?
Check to see if the motor burned out by doing a continuity test of motor windings.
Dec 24, 2015 | Magimix Food Processors
I am looking for a Magimix Food Processor cutting blade
Email your local Magimix distributor with a photo of the machine, the blade and the motor shaft. If you strike someone old enough they may recognise it.
Sep 16, 2014 | Food Processors
Can I change the plastic motor spindle on a magimix 5100?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and suppert the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 29, 2014 | Magimix 5100 Cuisine Systeme Food...
How do I change the Nylon Driveshaft on my Magimix 4200?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and support the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 26, 2014 | Magimix C.s.4200 xl chrome mat - Mixeur...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Motor keeps stopping
If you are making it do alot of work it may be slowing down enough to heat up. This will trip a thermal cutoff. Fortunately that one resets and you don't have to have an expensive repair. But now it may have overheated a few times and will start to burn off the varnish that insulates one winding from another. It will eventually burn out if you work it too hard. Can you get a more powerful one? Do you do this often?
Nov 26, 2013 | Magimix Food Processors
Dead motor in Magimix Cuisine 5100
Remove and check if there is any fault of a brush contact or switch contact or if the load trip switch had reset.
If the power is coming to the motor and is not running you need to confirm fully if the windings are open , if so replace motor.
if not remove and reset the setting of the brush/commutator.
Sep 24, 2010 | Magimix 5100 Cuisine Systeme Food...
Magimix 5100 Cuisine Systeme Food Processor Logo
194 people viewed this question
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
