Question about VistaQuest 8" Digital Photo Frame
I can't figure out how to re-orient some of my pictures to be right side up on my VistaQuest 8" Digital Photo Frame VQ0801W. I need to rotate some so they aren't on the side.
I uploaded my photos from my computer but the pictures that are originally on portrait orientation are lying on their side while the landscape photos are correct.I tried to rotate them in the file while it was connected to the computer but that didn't work.
    Sergeant:
  • 325 Answers
We use Picasa program to manage our pictures and videos. It's a free program and it works great. It should also help to fix the problem you have. Let me know if it helps!
Posted on Dec 27, 2013
How do I change the pictures that are the wrong orientation for the frame?
if its all pictures. go to the settings and look in the preferences for "orientation"
if its just one picture that you want to adjust do it before you upload it it the frame. if you use windows click on filename, go to review, use the rotation button. save it. upload. done
Feb 24, 2015 | PANDIGITAL 7" Digital Photo Frame With...
Why do my pictures come out sideways
Turn them around in your laptop first and then transfer them. It is the screen resolution that is not compatible.
Jun 26, 2014 | VistaQuest 8" Digital Photo Frame
How do I select to use the internal memory on my photo frame?
www.vistaquestcorp.com/lang/en
Consider writing to them and get operating instructions.
Jun 23, 2014 | VistaQuest 8" Digital Photo Frame
Why does my digital picture frame rotate some pictures?
The picture orientation can be set manually.
You can download a manual here:
http://resources.kodak.com/support/pdf/en/manuals/urg00863/M820_M1020_frames_exUG_GLB_en.pdf
Check chapter "Changing your frame orientation".
May 07, 2014 | Kodak Easyshare M820 Digital Photo Frame...
Pandigital picture frame manual
Unfortunately, there is no way to permanently fix the sideways photos while in the photo frame device. The only way to permanently fix them is to rotate them in your computer, and save them that way in the computer then re-upload the corrected pictures to the frame. Oh ya, you will have to delete the un-rotated pictures from the frame also.
Note: if the same name is used in both spots then the frame will take the newer one when it is overwritten on the upload to it therefore you will not have to go back and delete them manually!
Good Luck!
Rich Lilja
Jan 06, 2014 | Photography
Can't get any of my personal pictures to show up on the digital picture frame at all
Check the max resolution of you pic frame (800x600), you may have to resize your pics down in res until they display. Take one pic that will not display and reduce the size 6 or 7 times on a memory card.( ... Make it a litter smaller each time) Then load and show each one until it is displayed. You have found your target size...
Jan 04, 2014 | VistaQuest 8" Digital Photo Frame
Sylvania sdpf 1089
Rotate images correctly. : NIX Digital
https://support.nixplay.com/entries/66055804-Rotate-images-correctly-
Apr 7, 2015 - images that are uploaded to the frame should always display .... I amdisplaying images from my SD card. ... of photos coming from USB or SD will stillneed to be rotated if there is an exif ... "save as " from the account they are the correct orientation on my computer. .... Everything worked correctly after that.
Photo Rotation Problem - Community@Insignia
community.insigniaproducts.com/t5/...Photo.../Photo-Rotation.../td.../508...
Dec 28, 2009 - I have a few pictures that I already rotated correctly on my computer. Even so, they display incorrectly on the digital frame (buildings and people. ... When I bring the picture back to the picture frame, the rotation is still .... Just extra info - If I put the picture directly into Internal Memory .... Save as 24-bit Bitmap.
Galaxy S3: Photos are always being rotated! Why! - Android Forums ...
forums.androidcentral.com > ... > Samsung Galaxy S3
Dec 31, 2013 | Office Equipment & Supplies
Some of my stored pictures display upside down
You need to use a PC to rotate the images to a correct orientation, then put the images back in the photoframe!
Oct 23, 2012 | Philips 7008 8-INCH DIGITAL PHOTO FRAME
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
VistaQuest 8" Digital Photo Frame Logo
241 people viewed this question
Top VistaQuest Photography Experts
Tony
Are you a VistaQuest Photography Expert? Answer questions, earn points and help others
