Question about Kodak EASYSHARE M1063 Digital Camera
BATTERY NOT CHARGING
MY BATTERY WILL NOT CHARGE AT ALL. I EVEN PLUGGED IT TO MY COMPUTER AND STILL WON'T CHARGE/ hELP
  • beverly_john May 18, 2009
    I just got this camera, two weeks ago. How long does the battery normally last? About how much a new battery will cost, and if that don't work then what? Thank you.
  • Kodak Master
  • 19,396 Answers
When that happens you usually need to replace the battery.
Go to any authorized shop and test a new battery before buying the replacement part.
Posted on May 18, 2009
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
My laptop says its plugged in but not charging, what is the problem?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 11, 2012 | Dell Computers & Internet
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
Battery not charging, how to I reset it?
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 25, 2012 | Acer Aspire 5741-6073 Intel I5 2.27ghz...
Battery won't charge even with a new battery
There could be something internally wrong with your laptop. Take it to a reputable dealer to help fix the problem.
Jul 10, 2017 | Toshiba Portege R705-P40 13.3" Notebook PC...
My laptop won't charge even it is plugged in.
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Loue Benison.
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think senerio 2 is the most likely, although you will have to test senerio 3 by removing the battery and pluging in your charger and seeing if the laptop powers on.
If it does power on then that rules out senerio 1 and 2 leaving a faulty battery.
Take care!
Dec 14, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
My laptop is not charging. it says 0% available (plugged in, not charging) plz help i have a stock hp pavilion dv5
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 25, 2011 | HP Pavilion dv5-1138nr Notebook
My laptop wont charge.when its running low at 10% i plug in my battery adapter it says its plugged in but not charging. I can only use it when my adapter is plugged in and i've left my computer sit shut...
May 02, 2011 | Computers & Internet
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Kodak EASYSHARE M1063 Digital Camera Logo
242 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
