Question about Ricoh Aficio 450 Copier
Need setting heather unit but not going out sc code
  • Ricoh Master
  • 1,294 Answers
First resolve the sc code error defect,after you can acces settings.
Posted on Jan 03, 2014
Po106 code chrysler town country
Hi Heather, I'm glad to help! Heather, provided you have a good vacuum going to the Map Sensor and wiring and connectors are good. That would be the first thing I would replace. But, if after checking wiring and connectors and a good vacuum you replace the map sensor and still have the code I would have it check out for a possible (PCM) Powertrain Control Module. Hope this helps and have an awesome day Heather!
Apr 17, 2014 | 1996 Chrysler Town & Country
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
I can't get surround sound when I want to watch a dvd. I need to know how to set it up properly. This is for a Panasonic Home Theater Audio System MODEL NO. SC-HT65
the wires are color coded, follow the color coding on the wires, and connect the wires to the proper color coded connectors on the back of the main unit or go to panasonic.com to get the manual online for that model
Jan 21, 2011 | Panasonic SC-HT65 System
Fan heather not work
If you have the model number of the unit ( a series of Letters with a few numbers in it). You can go to www.desatech.com and find the manual for the unit under "Wall Heaters." In the manuals there are usually troubleshooting guides. Hope this helps!
Mar 15, 2010 | Desa International Blower Glow Warm Wall...
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
Sc 322 on a 3045. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont...
Another poblem with this machine is that the sync detect for the 400 dpi and 600 dpi could be off. Go into service modes by pressing the yellow clear modes key then pressing the numbers 1 0 7 then hold done the red stop key till you see the display change. Now go into copy sp, then hit the 2 in the window {drum}, next use the page down button located in the middle of the screen till you see the one that says 2109 LD Beam Pitch Adjust. Go to number 2109-8 beam pitch data reset. execute then go to 2109-1 and set it to 144 then hit pound. Now go to 2109-3 and execute. last go to 2109-2 and set it to 168 then hit pound. Now go to 2109-4 and execute. exit out of the service modes window. now try to run a copy and a print. If these fail the you either need to clean the laser assembly, a polygonnal mirror moror or laser drive unit.
Oct 16, 2008 | Ricoh Aficio 1035 Copier
TTL Multi-Flash Sync Cord SC-27
YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
AND SHOOT THE FLASHES IN SETTING 4A
NO CORDS NEEDED THEN .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
Ricoh Aficio 450 Copier Logo
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
