Question about Genius Tablets & eReaders
How to replace touch screen on Allfine Fine7 Genius KNC MD716
I have an Allfine Fine7 Genius KNC MD716 the touch screen doesn't work. It powers up but cannot unlock with sliding the open lock. i have found where to get a screen from but don't know how to fit it
How to hard reset prestige eliet visual land tablet
Hard Reset To hard reset your Visual Land Tablet, you need to follow the instructions below carefully.
1. Turn off the tablet.
2. Press and Hold Volume Up and Power button at the same time.
3. Keep holding the buttons till you see the start up screen.
4. Press Volume up five times when you see the android with an exclamation to reveal the recovery menu.
5. Since touch screen doesn`t work on this mode use Volume and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Apr 01, 2017 | Tablets & eReaders
Can i buy a new screen for my icraig tablet cmp759
Replacement Touch Screen for iCraig Craig CMP756 Dual Core 9 ...
www.actablet.com/replacement-touch-screen-for-icraig-craig-cmp756-dual-core-9-in...
  1. Cached
  2. Similar
Digitizer Glass Capacitive Touch Screen Panel Replacement for iCraig Craig CMP756 Dual Core 9 Inch Android Tablet PC Features: Brand new, original touch ... Missing: cmp759
Amazon.com: Touch Screen/Panel Digitizer Glass Replacement Parts ...
https://www.amazon.com/Screen-Digitizer-Replacement...Tablet/dp/B00J09P2SM
  1. Cached
Buy Touch Screen/Panel Digitizer Glass Replacement Parts for CRAIG CMP738b 7" Tablet PC: Screens - Amazon.com ? FREE DELIVERY possible on eligible ... Missing: cmp759
LCD Display Screen Replacement for Craig CMP745e iCraig ...
https://www.amazon.com/Display-Screen-Replacement-Craig.../dp/B00LTB655S
  1. Cached
There are two layers of screen for a tablet. The one on the top is a touch screen, which works for the function of touch. The other below is the LCD screen, which ... Missing: cmp759
craig tablet cmp759 replacement screen - Buy Wholesale Phone ...
m.totobay.com/wholesaletags/craig-tablet-cmp759-replacement-screen/
  1. Cached
Items 1 - 20 of 5498 - craig tablet cmp759 replacement screen - Wholesale craig tablet ... Craig tablet 746e screen replacement icraig CMP759 screen panel ...
Craig Electronics Inc.
https://craigelectronics.net/
  1. Cached
Whether you are looking for audio products like our Bluetooth/WiFi Speakers, or portable products like our Action Cameras, and Tablets, we bring you the ... icraig tablet cmp759 Google Search
Feb 01, 2017 | Tablets & eReaders
Touch screen wont work
Simple touch glowlight 2012 model. My touch screen wouldn't work. I had full battery. I couldn't power down using the power down button, I had to force it to shut down. I couldn't slide the unlock nor could I turn pages with screen. I only could turn pages with buttons on side. After much research I found that it just needed a simple cleaning. I used a vacuum to gently suck out dust in the crevice of the screen. Or you can use a canister of air to blow the dust out. Do this at an angle so that you don't blow it deeper into the crevice. Also, Use a cloth misted with H2O (almost dry) to wipe the screen from edge to edge. These screens use sensors that are from the side of the screen.. Debri will block the sensors. Mine works great. Too bad I already purchased another one after I found the solution.
Feb 13, 2014 | Nook HD+
No power
Pull the SD card from the top and make sure you have the appropriate update from the cruz website on it. Follow flash instructions.
Test the power cord with a voltmeter to see if its giving power. ****** works well too. Not really don't do that, I mean it'll work but get a tool to check it. Someone who works on cars or their house will probably have one.
If that doesn't work, open the back, pull the battery plug and then plug it back in. If it still doesn't turn on you're probably beat. You can look further into digging in and removing other internal parts to attempt to reset whatever it is that is wrong but most likely it's an issue along the power line on the way in or the jack itself. If it had a surge it'll be something further that is fried. In most cases you're buying a new one.
Keep an eye out for the t301 its much more capable and prices drop to about $70 during sales. The touch screen is real (capacative) which is a major improvement and you have a lot more space to download stuff.
goodluck
Dec 06, 2011 | Velocity Tablets & eReaders
I have white spot on my ipad screen, any advice how to fix it?
I would recommend taking the ipad to the Genius Bar to have them review. This sounds like one of two things: a stuck pixel or backlight bleeding. The stuck pixel might be able to be resolved by massaging or flashing different colors on the display. Besides replacement, there is no fix for the backlight bleeding.
May 20, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tecra m7 doesn´t boot up
mine does the samething have you found out what the problems is yet?
Dec 23, 2008 | Toshiba Tecra M7 Tablet PC
Tablets & eReaders Logo
89 people viewed this question
Top Genius Tablets & eReaders Experts
Are you a Genius Tablet and eReader Expert? Answer questions, earn points and help others
