Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate Care II will not spin and makes a loud noise, I did get it to drain the water.
  • 9 more comments
  • BL43 Nov 12, 2007
    Mine will not spin or agitate. Water does drain, timer works, and switch works. Sounds like a clutch engaging during the agitate/spin cycle. Any idea's. I have the washer apart right now (needed a good cleaning anyway) but looking for some advise.
  • Anonymous Dec 26, 2007
    So. Fix or relace the washer?
  • RFShortt Dec 27, 2007
    I have the same problem. I'll start to check the motor / gearbox coupling first, then the agitator from the top. It's great these things happen around the hiliday time when cash is tight !
  • ramphead May 03, 2008
    at spin time the pump is pumping but the basket is not turning .
    lift the lid then close the lid , the pump and basket now turn together .
    whats happening .
  • buynew May 07, 2008
    My washer does not always spin out, I have replaced the coupling - did not solve problem, the size of the load seems to make a difference, I can empty the washer, get it spinning then add clothes and it works fine, Worst with towels
  • Anonymous Aug 26, 2008
    the washing machine will not spin and makes a loud noise. It does wash and agitate. I pulled the hoes off on the pump and couldn't find any trash in it. What could it be?
  • Anonymous Oct 04, 2008
    does not spin or agitate
  • terryfixya Oct 18, 2008
    My whirlpool ultimate care II will not spin and makes a loud noise when it should be agitating the wash and when draining
  • kizabee Oct 20, 2008
    I am able to get through every cyle on my machine except the spin cycle. It will agitate, but it will not spin the excess water off. WHat could be the proble?
  • frasierty Oct 21, 2008
    I have checked the coupler, and it looks fine. Looking for advice as to what to check next. Thanks
  • Anonymous Mar 15, 2014
    Whirlpool ultimate care II has high pitched whining noise when operating
  • 248 Answers
The usual culprit is the motor-transmission coupler. This is located between the motor and the transmission. You need to remove the pump and then the motor to access it.
Posted on Nov 08, 2007
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here.
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
568 people viewed this question
Dan Webster
Dan Webster
Sal De
