Question about Royal Jaws Shredder
Shredder No Longer Does
The motor runs, the gearbox grease is still greasy and not hardened, yet the "jaws" have quit working. When turning a gear on one side of the gear box, by hand, the gears on the other side do work. I suspect the gears between the motor and the gear box or the gear box to the "jaws" are no longer meshing well enough to operate the jaws. Any solution to this other than buying a new shredder? Less expensive solution, of course.
  • Ben Arnold
    Ben Arnold Dec 27, 2013
    Thanks, Tom. I'd pretty much decided that there was no help for it, but to buy a new one. After all, this one has been in service for more than a decade, so I think I got my money's worth out of it.
    Top Expert:
  • Royal Master
  • 45,112 Answers
Office shredders, even the heavy-duty ones, tend to jam up over time and have to be cleaned up to restore operation. If you have removed all jammed paper bits and still get erratic operation, the shredding process may have bent or broken some internal parts. It is not economically practical to try to repair. Better to buy a replacement.
Posted on Dec 27, 2013
  • Ben Arnold
3 Suggested Answers
  • 1218 Answers
SOURCE: I have VF800 royal shredder. the motor runs but
Contact ROYAL at 1-800-524-0799.
Posted on Jun 02, 2010
  • 1218 Answers
SOURCE: How do I go about getting replacement plastic
For Royal parts and prices give Royal a call at 1-800-524-0799.
Posted on Aug 21, 2010
My shredder has the sound like it is working, but it is not shredding.
From your description, it sounds like when you insert the paper the motor turns on, but the paper is not pulled into the shredder, indicating the two shredder cylinders are not turning. The most likely cause of this is a stripped (missing teeth) main nylon gear. These can be replaced but require some effort.
Apr 17, 2014 | Royal Office Equipment & Supplies
Works in reverse but motor stops running almost immediately when turn to shred. have used only about 1 dz times although have had a year. model as662c
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Apr 14, 2011 | Aurora Electronics AS662C Shredder
I have an office max shredder OM99729 that quit working. the motor runs but it won't pull the paper into the shredder. I opened the cover and found the gear is stripped that runs directly off the motor....
I have the same unit witht he same gear off the motor that has a couple of teeth srtipped. Anyone out there know where to get a replacement gear?
Thanks...
Dec 22, 2010 | OfficeMax 0M96431 Shredder
Blade no longer turns yet can hear motor is working. model 48271. Still within 2 year guarantee but cannot find receipt
inside the mixer is a gearbox if the gearbox has striped a gear tooth or striped a drive pin the motor will run but the mixer wont turn the blades sorry its not good news for you,
Nov 28, 2010 | Morphy Richards Kitchen Appliances -...
Gears are not turning but fan is running No apparent jam but have difficulty manually turning gears
Shredders normally are hard to turn by hand....check to see if any gears are broken or stripped....take one gear out so the motor dosn't have to turn the cutting shafts...once you determine problem give Royal a call at 1-800-524-0799 for parts and prices.
Jan 13, 2010 | Royal Jaws Shredder
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
XF50D motor won't turn shredder blades
There is no viable solution.  There are no replacement parts available.  The Office Depot shredder is a cheap low quality product made by a cheap company.  The FIXYA service agreement costs more than the product.  Bad choice to buy the product!
Dec 07, 2008 | Office Depot Ativa DQ60M Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
Shredder motor sticks
Call Fellowes Customer Service 1-800-945-4545
Oct 28, 2007 | Fellowes 220C-2 Shredder
Royal Jaws Shredder Logo
116 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
