Question about Sony Audio Players & Recorders
NWZ-B172 WHEN I CONNECT TO THE COMPUTER IT WORKS PROPERLY BUT WHEN IT IS EJECTED IN WON'T OPEN
IF MY WALMAN IS CONNECTED, IT SHOWS STORAGE, BUT VERBINDEN M. USB IS SHOWN TO MY WALKMAN IF IT IS CONNECTED. BUT IF IT IS EJECTED, IT WON'T OPEN. I TRIED TO OPEN IT FOR MONTHS TILL I STORED IT AWAY. BUT NOW I LOOKED AGAIN FOR SOLUTIONS. PLEASE HELP. THANKS
  • 5 Answers
SOURCE: mp3 will not connect with my computer
I had the same problem. Don't buy a new cord. There is a sony place in winnipeg you can get it fixed there.
Posted on Jun 02, 2009
  • 89 Answers
SOURCE: nwz-e438f will not play, or connect to computer
Please try connecting the Walkman to a different USB port on the Computer and check if that helps.
Please make sure that there is no other USB devices connected to the Computer at the same time.
If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Keep the Walkman connected to the Computer for 4 hours to fully charge the battery. Then, check whether the Walkman is working properly.
Ensure that the HOLD switch is not activated.
If the issue still persists after performing the steps provided above service of the Walkman is required.
Posted on Jun 16, 2009
SOURCE: sony nwz-b135f problem
MTP problem SOLVED!!!!! Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have a Sony MP3 Player(NWZ-B135F). when i inserted it to my pc's USB port(which is working fine), win XP (SP 3) prompted "Found New hardware" wizard. I followed the steps and finally I reached to a step where it shows “MTP device Problem......” I tried many times with different USB ports, but the same problem happened.
Fully frustrated, I finally did what the whole world does, GOOGLE my problem. Google showed me a lot of posts but nothing could solve my problem. Microsoft was providing the MTP driver, but only after a lot of authentication and procedure, which I was not going to follow….
After repeatedly experimenting by inserting my MP3 player, I got the solution!! It is as follows:
1) Insert your music player in the USB port. You will get a Hardware Installation wizard by XP.
2) Select, “No, Not this time” and click next.
3) Select “Install from a list or specific location (Advanced)”.
4) Select “Don’t search. I will search the driver to install”.
5) Select “USB Mass Storage Device” and then click "Next"
7) Wow!! Now you are done!!!
Enjoy and listen to your favorite music!!
Posted on Jul 03, 2009
SOURCE: New Sony NWZ-B133F/BCE Walkman does not show as removable drive
I bought a new Sony NWZ-B133F/BCE Walkman. When I plugged it to the USB the drivers got properly installed, but the player does not show as a removable device or any other device in My Computer.
just follow...be sure your player is connected to pc
go to my computer right click>>properties> IN HARDWARE TAB select device manager>portable audio>right click select update drivers>click next>tick the option let me choose driver for this device>next choose usb mass storage driver from two options click next....
AND U R DONE....
Posted on Mar 16, 2010
p4prince2par
  • 285 Answers
SOURCE: sony walman sok-nwz-b135f(b)
firmware is corrupted reinstall firmware from sony site
Posted on May 24, 2010
I purchased SOny NWZ-S544 Walkman. when i connect it to my laptop (Windows XP OP) it will not show up unlike other device, so i cant access it through my laptop pls help
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope I could help you.
Thanks.
gylacz
Aug 01, 2011 | Sony NWZ-S544 Digital Media Player
My sony nwz-b152f is not accepting .i need adriver for that
Good work and luck!
gylacz
Jun 24, 2011 | Sony Walkman NWZ-B142 MP3 Player
HOW TO OPEN THE NWZ W252 PLAYER ?
Here is the official manual online: Sony NWZ-W252 MP3 Player
When you mean "How to open", do you mean How do you open the player on your computer? If that's the case, if you have a Windows based Operating System, you should be able to just to to "My Computer". then once you have connected the mp3 player to the PC, the mp3 player will show up as an extra storage Hard Drive logo on screen. Once that appears you can drag and drop MP3 music files onto the device.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 08, 2011 | Sony NWZ-W252 MP3 Player
My Sony Walkman MP3 Player NWZ-B142F not visible on my desktop when connected through usb. But it shows as it is getting charged
When your MP3 is connected to the PC.
Click start -> Right-click 'My Computer' -> Properties -> Device Manager and your MP3 may show up with a yellow exclamation mark next to it on this window. Right click it and select 'Update Drivers'. Click next, Tick the option 'Let me choose driver...' then choose USB Mass Storage Device and click next and it should work.
Other than that try opening Windows Media Player, if you don't have it installed you can download it here: http://windows.microsoft.com/en-US/windows/products/windows-media-player
It might show up in there.
May 07, 2011 | Sony Walkman NWZ-B142 MP3 Player
Sony nwz-b142 doesn't display in my computer. I already tried installing the device in the control panel and it says device works properly and yet it doesn't display in my computer
This advice could help you if your player works properly and the problem is in your pc only:
At first you should be sure that your USB cable can work.
Then let's see the PC.
gylacz
May 03, 2011 | Sony Walkman NWZ-B142 MP3 Player
My sony walkman NWZ-B135F MP3 Player is not working at all. i connected the player to my computer to recharge which after awhile i decided to eject it properly but when i removed the player it's already...
Try to press the power button while it is connected to your computer. See if it will show up charging. If it is not, then you may need to contact Sony Support.
Oct 13, 2010 | Sony Walkman NWZ-B135 MP3 Player
Sony walman sok-nwz-b135f(b)
May 24, 2010 | Sony Walkman NWZ-B135 MP3 Player
Sony walkman model nwz-a726 not charging
my sony walman nwz-a726 wont connect to my computer
Feb 11, 2010 | Sony Walkman NWZ-S616F MP3 Player
AND U R DONE....
Mar 17, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
64 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
