HP LaserJet 5500dtn Color Printer Logo
FavaRecords Bahamas Posted on Dec 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does processing job take long? - HP LaserJet 5500dtn Color Printer
Robert cruse
Level 3:
Master:
  • HP Master 336 Answers
  • Posted on Jan 11, 2021
Robert cruse
HP Master
Level 3:
Master:
Answers
336
Questions
22
Helped
299694
Points
1037
Many Reason Behind for Printer is Printing Slow
Multiple printing command at a time
Printer cleaning Services not done from time to time
Ink cartridge problem
Printer driver issues
Printing in draft or DPI mode setting
Printer Wireless network issues
You have to need to printer setup services expert to resolve this problem
Pete Fotheringham
Level 2:
Novelist:
  • HP Expert 175 Answers
  • Posted on Jan 30, 2014
Pete Fotheringham
HP Expert
Level 2:
Novelist:
Answers
175
Questions
Helped
85826
Points
280
The print file detail may be multi-layered may be too much information in print job- your printer memory may not be adequate, you may be printing through a slow network, you may be printing through an older print server which is as slow as parallel port printing or you may be printing through your parallel port which is slow.
How i can reset factory default tvs platina dp 5000 printer.
Use the following procedure to perform a network reset.
1. Turn off the printer.
2. Press and hold the Job Cancel button.
3. Turn on the printer and continue to hold the Job Cancel button for approximately 10 seconds,
but no longer than 20 seconds. During this process, the Attention light turns on.
4. Release the Job Cancel button. The Attention, Ready, and Go lights begin cycling from front to
back. After the network-reset process is complete, the device returns to the ready state. PC App Market Download latest software apps and games for PC from PC App...
3answers
Stop Printing
Hi and thank you for using fixya:
To stop your printer from printing while printing press stop or cancel in your printer control center. Also you can click stop or pause on your computer print dialog box,
1-right click on top of the printer
2- click pause on current job printing
good luck!!
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
2helpful
2answers
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
1helpful
2answers
Print job stuck in printer que
Try to power off your computer and printer and let it stay for 5 minutes. Then turn on your printer and computer to see if pending print jobs we're cancelled.
If the problem still there, you can kill the spool process running on your taskbar. Press control + alt +delete button to open the task bar and delete the process from the processes tab.
2answers
Deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
1helpful
The processing/data light is flashing....what to do??
There is a job waiting to be processed. Need to check status monitor to see what is waiting. If it is not critical you can cancel the job from that same screen.
Because you have an i model copier it must be setup to print and scan also. Someone might have sent a job that could be processed for one reason or another. Look in the bottom right side of touch screen for status monitor and see what details it has.
Hope this helps
TankMurdock
6helpful
HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
k24674
Grand Canyon Tech
Grand Canyon Tech
