Question about Maytag 24 in. DWD1500A Built-in Dishwasher
My whirlpool dishwasher (model # DU1055XTPB3) has a flashing clean light, hitting cancel runs drain, but then flashing clean light returns
4 Suggested Answers
  • 148 Answers
SOURCE: dishwasher does not drain
If you cannot get the diswasher to drain there is some obstruction in the drain line going to the disposal. First turn the power off to the diswasher at the breaker panel then open doors under sink and follow drain line to the disposal there you will find a hose clamp(silver) that you must loosten with a flat blade screw driver ( get a bucket under the disposal) pull the drain line loose and dump out excess water and debris inspect area going into the disosal to make shure it is not clogged up
reverse your proceedure and reconnect the drain
Before trying the dishwasher take some ice cubes and run thewater then put in disposal and turn on that should clean the disposal
try your dishwasher I forgot to mention that theri is a strainer at the bottom of you dishwasher that you can remove to be sure it is not clogged up I assume that you have aready checked that
good luck
Posted on Dec 30, 2008
rickead1
  • 1998 Answers
SOURCE: why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Posted on Nov 17, 2011
Testimonial: "Rick Ead's rapid response led to a solution within an hour. His suggestions were correct and after figuring out the button combination for out particular machine we were up and running."
  • 110 Answers
SOURCE: my Maytag Dishwasher wont run
check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Apr 18, 2012
Whirlpool DU930PWP02 Start Light Flashes 3 Times and does not run
Sounds like the anti flood alarm has activated - may be a small leak from the door or the sump into the base tray. You need to drain the tray, fix the leak and test. Try cleaning the door gasket and part of the door it seals against.
Feb 04, 2018 | Whirlpool Dishwashers
Whirlpool dishwasher model number GU3600XTSY2 is flashing: The clean light is flashing! It's not the heater circuit either. It says the dishwasher is malfunctioned. Call for service to check heater...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Mar 17, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashing and unit wont run
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 24, 2009 | Whirlpool Dishwashers
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Nov 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
FLASHING LIGHT AT END OF PROGRAM
what does the green light say hit cancel it may be a reminder that the dishes are clean if you give me the complete model i can look up the tech sheet a stuck button can also flash rapidly cancel will clear it
Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Maytag 24 in. DWD1500A Built-in Dishwasher Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
