Question about Cameras
Nikon coolpix My pictures are always blurry and even when I attach a tripod. The camera makes no sound but the results are horrible
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Not sure what Coolpix you have, I assume one young one. Not knowing how you did set up the camera, I even have to guess more.
I start with a questions, and I hope when you try to answer this, you will take the camera in your hands. You even could look into the manual if you have it, or pick up the manual on Nikon USA.
Did you put your camera in any other mode then the automatic mode?
When the dial is on the green camera logo, you should be fine. If not, try to switch to automatic and take a picture.
Be aware if you put the camera on a tripod, you should switch off the image stabilisation, because the camera is fixed and nay correction, will cause blurr.
You also should look if the front of the lens is clean. Don't start rubbing the front element, only use the correct lens cleaning cloth or lens pen. Never use a paper towel or any fluid, that is not special made to clean a lens. The coating of every lens is essential for its sharpness and for correct colour. With a little alcohol you ruin every lens, because it could resolve the coating. Please, if you still have problems, tell me what model coolpix you use and does not what you want.
Posted on Dec 27, 2013
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
SOURCE: Nikon Coolpix L4
Go to RESET ALL, thaty should get rid of your problem.
Posted on Sep 14, 2008
SOURCE: blurry pictures, HELP ME PLEASE!
I'm currently having the same problem. :[
You might want to check and make sure your lens in on the "A" setting and not "M". This can be found on the side of your lens.
Posted on Nov 25, 2008
emissionwiz
  • 79865 Answers
SOURCE: I attach Nikon CoolPix S550
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Posted on Nov 25, 2009
  • 1170 Answers
SOURCE: nikon coolpix s630, lens error, blurry, ticking sound
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 31, 2010
Nikon Coolpix S32 watreproof camera doesn't focusing properly
You have to know if the FOCUS is the issue or SHUTTER SPEED. In most cases with most CoolPix Cameras if the Image is not in focus (When you push shutter down HALFWAY) the Focus Rectangle will not be GREEN... If it RED it cannot focus. If every time you take a photo the focus area is red then it is not focusing. Small Coolpix cameras have difficulty focusing in low light.
Low light can make a hand held image look blurry because of hand shake. If the light is so low it wants to take a long exposure. This works with a tripod, but not with a hand held photo. With most of these small cameras you can take 1 second night photos with a tripod. They would look horrible handheld.
Typically on the Coolpix cameras you can set the FOCUS mode. It is usually shown with a FLOWER for MACRO... You get AF / FLOWER / MOUNTAIN / MANUAL (may not have this)
Plase make sure your FOCUS MODE is in AF AF is the ONLY Mode where the camera will focus CLOSE and FAR... Light is not your problem..... It seems it is your FOCUS MODE.
Jan 21, 2017 | Nikon Coolpix S32 White 13.2 Megapixel...
Why do I get blurry pictures on screen even when I'm focusing.
Go to MENU. Then TOOLS. Make sure Motion Detection is in AUTO.
If that is on AUTO then Put the camera on a hard surface (like tripod) and focus and see if image is still blurry. Lastly, it is difficult to focus in some conditions. Move the focus point, you can click on the screen to change it. Blur can be caused by: long exposures, camera motion during photograph, bad conditions unable to focus.
The focus routine in this camera gets confused often. It can be frustration. It will only be in focus when it is GREEN before you shoot and the camera is not shaking. At night it can take great night shots with a TRIPOD and Exposure set to -1 to -2.
Dec 07, 2014 | Nikon Coolpix S4000 Digital Camera
Nikon coolpix troubleshooting
Not knowing exactly what coolpix you have, I only can give a general answer.
Be aware that most coolpix cameras with zoom have Vibration reduction. Always when you put a camera on a tripod, you should switch of the Vibration reduction. (even on the most expensive cameras or with a DSLR on its lenses)
Because when the vibration reduction is on, there is a part in the lens that is always moving and the movement will be guided in the correct direction when the detector senses a movement.
When you use a zoom lens it is wise to switch the vibration reduction on, as soon as you are taking pictures without tripod. It can compensate shake of the camera, so you can shoot with slower shutter speeds as without the reduction. But the pictures are never as sharp as shot from a tripod, without vibration reduction.
Jan 27, 2014 | Cameras
Nikon collpix l810 lens shake automatically
The Nikon Coolpix L810 is a great camera capable of taking very good and sharp pictures, even in bad light conditions. It has a Vibration reduction, that makes it even possible to shoot pictures without tripod when you zoom in very far. If normally with the same lens length you should need 1/200 of a second your camera should still be capable of taking that picture with only the same blur from shake, with 1/50 of a second. But if you ever should use a tripod. make sure you switch off that feature. Because the Vibration reduction, works with a staking lens element. that should compensate the movement of the camera, by shaking in the correct direction opposite to the movement of the camera. The element will still shake and so blur a picture, when the camera is placed on a tripod.
Don't try to shoot pictures with the zoom on full extension, in bad light conditions. That also won't work. Lots of things can be done with the camera, but to everything is a limit. Most of the time that limit comes sooner when there is less light.
Jan 06, 2014 | Nikon COOLPIX L810
I have Nikon Coolpix S80000. It becomes blurry when I use the telephoto lense and for night photos too. What settings should I have it on to avoid this? Anne
You could raise the ISO or better yet, use a tripod. In dim light and when using telephoto, the camera uses a slower shutter speed and any movement from you results in a blurry picture.
Apr 12, 2011 | Nikon COOLPIX S8000 Digital Camera
I JUST got a Nikon Cool Pix L22 but no matter what setting I use EVERY picture is blurry. I am an art teacher and understand shutter speed and aperture, I even used a tripod. The pictures are still...
Most likely your fisheye lens attachment is out of alignment. An internal element may have come unscrewed or unglued. The other option (I'm assuming you have already checked this) is that it is incorrectly attached to the camera - check your threads and make sure it wasn't cross threaded and that there are no blockages to the lens attachment being screwed in completely. If the fisheye lens is not in the correct position relative to the CoolPix lens, then the pictures will be blurry.
Nov 21, 2010 | Opteka Full Fisheye Lens for Nikon Coolpix...
Blurry pictures nikon coolpix
With autofocus digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
Finally, make sure that you have not left the camera in Macro mode. This is a special extreme close-up mode offered by some cameras, and it does not allow autofocus on objects at normal distances.
Oct 31, 2010 | Nikon Cameras
Lack of definition, blurriness.
Experiment with lowering the "exposure compensation" setting until you get the desired results. Also, don't forget to use a tripod.
Jul 15, 2010 | Nikon Coolpix L110 Digital Camera
The night setting results in blurry pictures
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Jul 15, 2009 | Nikon COOLPIX S200 Digital Camera
Blurry images on a Coolpix 5700?
This camera was in the time when the ccd had problems.
http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
Call Nikon concerning your camera. You can send it to them, they will estimate it, and may repair it for free if it is the ccd problem.
Apr 05, 2008 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
