Question about Maytag Neptune Washing Machines
Water not going to the rince compartment
The softener compartment does not empty out for the rince cycle
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
YOUR TUBE IS BLOCKED THAT RINSES INTO THE COMPARTMENT
Posted on Dec 27, 2013
SOURCE: Fabric softener compartment problem.
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?) I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
Posted on Jul 05, 2007
  • 213 Answers
SOURCE: Problems with fabric softener
you either have low cold water pressure being caused by the screens on both ends of the cold waterline being clogged by sediment or one of the solinoids for the water inlet is bad. try removing cold water hose and cleaning both screens if that doesnt help youll need a solinoid
Posted on Nov 20, 2007
  • 213 Answers
SOURCE: fabric softener not going into the machine
yes it should come in during the rinse cycle. if its not coming in at all then youll need to replace the valve that goes to the softener. to get to it take the top off the washer. youll see 3 valves where the hose connect. trace the hoses from the dispenser back to see which valve you need to change
Posted on Nov 27, 2007
  • 4 Answers
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Posted on Feb 05, 2008
The fabric softener compartment in is full of water. I need to empty this manually prior to each wash . Many, many thanks. Judy
The fabric softener dispenser has to be purged between wash cycles to prevent residue from clogging it. What you are observing is normal operation.
Jun 25, 2016 | Washing Machines
Hi My Bosch WD2460 is not taking in the fabric softener? I have cleaned out the drawer and run a cleaner through the machine it seems that the water isnt even going into the compartment?
the valve for this isnt right
or
its the intakes cold hot filters at the machines valves
or
the valve has failed for softner
usually any front loader
will add cold water perhaps hot if connected
run a cycle and after a couple of rinses will add softner
so it uses the same valve as rince{cold water}
so will be a dule valve and two channels
hot and cold one set of inlets
softener is one move valved ch of cold ...
so its blocked above the soap tray or at the valve
perhaps the value is gubbed
you can look see
could even just be gummed up with soap
its a complex job or out with the pipe cleaners from the local homebrew shop
clean then whole plastics of the machine in the bath of warm water
using some sponges
Mar 04, 2015 | Bosch Washing Machines
The fabric softener container doesn't empty during the cycle of the washing machine. Adding water manually does empty it - so I guess there's a problem with the fossit. The machine opens from the top. The...
It is more than likely that the water inlet orifice is blocked.Get something to poke into the hole or holes in the top of the soap drawer compartment over the fabric conditioner compartment.
This should solve the problem.
Dec 11, 2009 | Washing Machines
I need to run the dryer through 2 drying cycles to completely dry also using the sensi dry
Rince the lint trap off with hot water , when you do and water beads up on the surface, wax has built up on the screen from the softener and has pluged the screen, rince till water flows through freely, if this dos'nt work check the outlet and tube for lint buidup
Oct 17, 2009 | Kenmore Dryers
Fabric conditioner compartment doesnt empty properly. Ive tried cleaning out drawer but still no luck.
If you can remove the dispenser from the machine try soaking it in HOT water. The fabric softeners can cause a wax like build up that can clog the dispenser. If the dispenser will not come out of the machine then pour Hot water into it, cycle the machine and repeat. It took a long time to clog and will take a while to remove the clog(several cycles). This will work but will take time. Mix water with your softener to keep it from cloging again, it will thin the softener and stop the build up. If you add 50/50 water/conditioner shake well and use twice the normal amount so you are getting the full amount of softener/conditioner into the washer. This will help i had a similar problem with my front loading washer.
Oct 17, 2009 | Washing Machines
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Machine blocks at rince cycle
running empty or full makes no difference. problem may be not draining to test this, put some water in appliance from a jug then start the cycle. (first action is to drain) see if water disappears. get back to me if you wish
Apr 02, 2007 | Siemens WXLP1460 Front Load
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
