Question about LG 60PZ550 3D Plasma TV
Tv black out
The tv will stay on sometimes for hour and then black out for a little and come back on even with the x box
Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Apr 27, 2010 | Olevia LT37HVS 37 in. LCD HDTV
BLACK SCREEN · I TRIED TO RESTART MY PHONE AND NOW THE SCREEN IS ON BUT STAYS BLACK
I feel your pain. My g1 droped, the screen cracked, now 3 weeks later my screen turns black. Not even turning it off or removing the battery for hours changes this. However, i found if you wiggle the screen just right sometimes you can get your screen back... for a little bit.
Oct 17, 2009 | HTC G1
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Sansui tv shuts off by itself after being turned on.
the relay on the power board needs to be replaced; if you feel confident to do this:unplug the tv wait about a 1/2 hour then remove the tv's case carefully look for a small black or, brown box about 1/2" x 1" x 1/2" this relay should have a designation such as Rly 1 printed on the circuit board it must be unsoldered and, removed the numbers on the relay can be entered into a search engine to find a replacement
May 03, 2009 | Sansui TVM1316 13" TV
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Nov 16, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
LG 60PZ550 3D Plasma TV Logo
Computer Repairing
Computer Repairing
