Question about Tablets & eReaders
MY BINATONE 2282 README WILL NOT POWER UP. ONLY USED IT ABOUT 60HRS OF USE HAVE CHARGED IT UP (RED LIGHT LIT UP) BUT IT WILL NOT POWER UP TRIED USING RESET BUTTON BUT NO LUCK ANY IDEAS
Device is not charging
Try using a different cable, if it works, continue using the other cableIf the other cable does not work, try using a different charger Also refer to:
Battery Won Stay Charged
Feb 22, 2016 | Amazon Kindle Paperwhite
When I plug in my device and try to turn it on the battery light glows red and a red light instead of a blue one will light up and I know I have charged the battery
at least you think you charged the battery . I would take it to a computer repair shop and have them check the battery
Oct 11, 2015 | Tablets & eReaders
When I attempt to charge using USB charger the charging light is red for a couple of seconds and then goes off. I have only just received this case/keyboard. It is obviously not already charged since the...
Turn the keyboard on and let it run all the way down. Then try charging again. If the Red light stays on, the keyboard has was charged. If the same conditions exist, then arrange for a replacement.
Mar 28, 2015 | Tablets & eReaders
My kocaso tab wont turn on whille charging
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Dec 28, 2014 | Kocaso Sx9700
Wont start up
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
I have forgotten my passcode to get inton my binatone 742 homesurf tablet can i unlock it?
All I want is to unlock pattern for my second hand home surf tablet, I can t do nothing with it so those who say connect it to laptop or PC etc. I need a solution that works and done without having to pay anything.
Jan 25, 2014 | Tablets & eReaders
My binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to service@shriro.com.au India customer service number +91 7503011385 or email to assist@binatonetelecom.in
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
Oct 21, 2011 | Tablets & eReaders
My kindle light won't turn on to awake and when I tried to plug in to charge,no light came on.
If the charge light won't even come on then it sounds like you have a dead battery in your kindle and need to replace it.
Call support and order a new battery.
http://www.amazon.com/gp/help/customer/display.html?ie=UTF8&nodeId=200212360
Mar 02, 2011 | Amazon Kindle 1
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
