Question about Icom IC-R5 Handheld Scanner
WORKING BUT WITH NO DISPLAY
THE SCANNER HAS NOT BEEN USED FOR SOME TIME NOW WHEN ITS SWITCHED ON THERE IS NO DISPLAY
  • 42 Answers
It is very likely that the batteries need charging, tip, charge them in a separate charger, if the batts are low, the scanner asks for confirmation to charge them (it is not automatic) and with no display you won't see this message and will forever keep trying to charge them without confirming "yes" for the scanner to do it!!.
Posted on Sep 27, 2009
Squelch on maycom 108 works on VHF but not Airband. Was working last week?
factory reset: Push and hold AI + FUNC and turn the scanner on.
The message INITIAL are shown in the display..
Now it's reset to the factory settings,
with 124 MHz stored i memory channel 1 in the Air band,
and with 156 MHz stored i memory channel 1 in the "VHF band".
Oct 08, 2016 | Maycom AR-108 Scanner
Scanner error 14
the problem with scanner assembly
Mar 20, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Kernel error on xerox synergix scanner
Im a xerox technician. It is impossible for the scanner to display this message. That is a rip message only.
Feb 12, 2013 | Office Equipment & Supplies
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
The device has experienced an internal hardware error.
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
Jul 09, 2011 | HP LaserJet 2840 Printer
Xerox C20 displaying "Scanner Locked" message. Won't copy.
  1. Press the power switch to the OFF (O) position. The power switch is located on the lower, left side of the machine.
  2. Pull the scan lock switch toward the front of the machine to unlock the Scanner.
    NOTE: The scan lock switch is located on the bottom of the Scanner Module. Make sure the scan lock is completely free. It sometimes hangs at the halfway point.
  3. Press the power switch to the ON (|) position. A 'Warming Up, Please Wait' message will be displayed on the Display Screen. Warm up time is less than 40 seconds from power ON and less than 25 seconds from the Power Saver mode.
Aug 30, 2010 | Xerox CopyCentre C20 Black and White...
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
How to unlock my M20i scanner
Release the lock, down the scanner is a tiny plastic piece between the oupt tray (the place where the paper goes out) and the top of the scanner
Fosg2000, Rate me please
Mar 16, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Scanner working but no display
first you check connection cbu to scanner 2. there is a switch in scanner you check on or off that switch should be on 3. did you installed scanner driver sotfwere
Feb 16, 2010 | HP ScanJet 8270 Flatbed Scanner
Using PaperPort 11 to scan
If you will go through the Advanced Setup wizzard and it completes you will have access to the "Display Scanner dialog"
Jul 18, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
BCD369T problem
You might be able to, if you understand how to reset the scanner's binary CPU board. But honestly, I had the same scanner with the same problem, and one way to fix it is to reprogram the entire scanner's memory. The second way is expensive, send it to a radio repair store. I'd recommend to just reprogram it and see if it works then. If no avail, you might need to have it looked at, but reprogramming it helped my problem. It's time consuming I know, but it worked.
Best Regards,
Gavin93
Jun 17, 2008 | Uniden BCD396T Handheld Scanner
Icom IC-R5 Handheld Scanner Logo
115 people viewed this question
Top Icom Radio Communications Experts
peter0911
spencer hughey
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
