Question about Konica Minolta bizhub C450P Laser Printer
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
It shows the error code soon after switching it on
  • Konica Minolta Master
  • 1,297 Answers
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Posted on Dec 29, 2013
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
Geekinator
  • 183 Answers
SOURCE: error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 16, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
firecontrol7
  • 6680 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
What does fridgidaire dishwasher error code pf mean
Usually the PF code means a power failure. You should check the wiring to the machine for loose wire nuts or wires with missing insulation touching each other or the side of the wiring housing. (You'll need to remove the access panel at the bottom of the dishwasher to check the wiring.)
If the wiring is fine, check the switches in the door latch. The white wires should test fine for continuity. If those switches are fine, then the control board has a wiring fault. Replace the appropriate parts. If your dishwasher is under warranty, contact Frigidaire.
If you add a comment with the model of your dishwasher, I may be able to help you find the replacement parts.
I hope this helps.
Sep 21, 2014 | Dishwashers
HP laserjet m3027 error code 49.4c02
if this error shows up with no network card installed, you have a bad `fomatter' board.
Apr 03, 2014 | Office Equipment & Supplies
Amana washer error code
This is an open door error. check the latch and switch on the machine.
Feb 05, 2014 | Washing Machines
I m having nokia c3.. i set its security code 123456 nd locked its keypad.. my sis tryed to open it with wrong password for 10-11 times.. wen i entered correct code its showing error.. can u suggest me...
so first switch off your phone and remove battery and sim card . and keep this for an hour. after one hour replace your sim card and battery on the phone . now switch on the phone and enter the same security code again this will now work. keep smile. have a nice day
Jun 19, 2011 | Cell Phones
I FORGOT MY NOKIA 1650 SECURITY CODE. AS SOON IS I SWITCH ON MY PHONE IT SHOWS ENTER SECURITY CODE....AND I DONT KNOW MY SECURITY CODE.... PLS HELP
hi
contact your service provider and format your phone. this will fix your problem.. format your phone and try it.. this will fix your problem
thank you
Dec 25, 2010 | Nokia 1650 Cell Phone
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Cannon gp200 - we have an error code 803-switch power on and off
we have an error code 000 - the message is switch power on and off- we tried this and the same code/message shows again please answer
Apr 03, 2009 | Canon Office Equipment & Supplies
Functional problem code SC542-00
SC542 error = Fusing temp. warming-up error.
The fusing temp. does not reach the fusing standby temp. within 125 seconds after the main power switch is turned on.
Causes:
Thermistor defective or out of position
Fusing lamp open
Thermofuse open
BICU defective
Power supply brd defective
Poor connections
ALWAYS DISCONNECT THE POWER FROM THE WALL BEFORE WORKING ON MACHINE
*** replace the thermistor AND the thermofuse*** If one went bad then the other will probably go bad soon. ( 95% it is one of these). You can check lamp first by disconnecting one end and putting a meter on it to see if it is open -- if open then replace.
Jan 21, 2009 | Office Equipment & Supplies
Fisher and Paykel model RF610 approx 4 months old door warning goes off as soon as fridge or freezer doors are opened. error code F24 showing in display screen also spanner symbol icon thingy flashing.
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Dec 19, 2008 | Refrigerators
Konica Minolta bizhub C450P Laser Printer Logo
1,946 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
