Question about Hotpoint Ultima WF860 Front Load Washer
How do I get to the drum of my washing machine
There is a whalebone stuck in the drum how do I get inside it to remove it ?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
WITH GREAT DIFFICULTY, IT TAKES AN HOUR TO STRIP A MACHINE. WOULD BE ADVISABLE TO GET A CHEAP REPAIR MAN IN
Posted on Dec 27, 2013
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
SOUNDS LIKE UN HAVE SOME ITEM OR COIN ETC STUCK BETWEEN THE TUB AND WALL. YOU HAVE TO REMOVE THE TOP PANELS THEN REMOVE RETAINER CLIPS AND REMOVE THE BODY TO ACCESS INSIDE DRUM
Dec 12, 2016 | Kenmore Washing Machines
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Bra wire stuck in washing machine
You could try a very thin pair of twezers, or a very thin magnetic pick up tool,you might be luck.. if not the only other way is to remove the ruber door seal to get acces to the inside of the drum.
Dec 28, 2011 | Electrolux Refrigerators
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Need to remove object in drum
I have a Punch WF-C5856TC topload washing Machine. How can I remove odject that have been stuck inside?
Aug 13, 2008 | Zanussi Washing Machines
How do you remove the drum?
well either pull it out with pliers from inside or you will have to split the drum cover.
You will have to remove motor hoses etc. and take out the whole drum housing.
Split it and pull wire out. If you go to this length please clean heating ellement too thna.
Not difficult just a lot of time..
Good luck
Jun 05, 2008 | Amana LW8203
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Sep 27, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
