Dell Dimension 8300 PC Desktop
Problem for Dell Dimension 8300 PC Desktop
PC KEEPS FREEZING UP ON LOG-IN
By marknewtonho on May 18, 2009
Hi, I have a Dell Dimesion 8300 and it have today decided to keep freezing on me. I have tried going back to last known working configuation however it gets to the point of displaying the icons for the apps and then freezes. The mouse can still be moved around the screen but when I click on anythgin it does nothing. Help!
Comments:
May 18, 2009
- I was worried that this might be the case. I don't suppose there is anyway I can somehow get all my docs/mails/photos off the PC before I do?
Many thanks
Mark
May 18, 2009
- Thanks, I will give it all a go.
Best Solution
posted on May 18, 2009
Very Helpful)
zohail
Rank: Guru
Rating: 92%, 1106 votes
Conficker Virus infected
if ur mouse moves and ur desktop frozen then it is not hardware malfunc it is definately a windows virus type try to login in safe mode if it doesnt help i worry u have to format ur hard drive and setup again all OS and applications u have this is the only solution and next time pls be updated in virus use pcc cillin or norton antivirus and update frequently and SCAN as well
Good luck for the remedy
Pls rate me WELL !
Regards
Comments:
May 18, 2009
- pls first try the procedure to remove the conficker if u can do it i was not able to some variants does not allow to do so
pls try it
http://support.microsoft.com/kb/962007
info on Conficker
http://technet.microsoft.com/en-us/security/dd452420.aspx
look if u want ur docs out of it and attach a disk to this disk it can get conficker as well and this simply multiply it
u see if it works in safe mode and u have access to dvd drive there u can backup data on dvd i suggest but i will not suggest connecting a hard drive to system and get ur data on it the conficker will transport to the backup hard drive and when u copy them on fresh system it will again strike
u can try it backup all ur data on Usb type if u have access to it in ur infected system , try backup disk Usb Stick or Flash drive and then first wipe off all ur infected hard drive and then conenct ur backup disk to backup data from it but pls install strong antivirus and update it first and then do the restore thing
pls follow all above guidelines if does not work then pls wipe off the hdd and start fresh and next time always keep ur imp data and files on other partition than OS partition and protect ur pc with good antivirus product and update and scan pc regularly
regards
Zohail
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dell Dimension 8300 PC Desktop
Questions and Unsolved Problems for Dell Dimension 8300 PC Desktop
Do you recommend Dell Dimension 8300 PC Desktop?
Answer
Answer
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of... (More)
Answer
My older Dell dimention 2300 created photo and audio Cd's do not play in my dell optiplex gx270 cd... (More)
Answer
titledeko pro key
Answer
program leaves tracers and the background turns white can't figure out why. and it runs very slow.... (More)
Answer
Not being able to run my software of the Princeton Review Math Library on my new Mac OS 10.6 or use... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
