Question about Baby Gear
How to assemble hinterland bbq - Baby Gear
Need assembly instructions for a jackaroo flinders 4 burner bbq
It is a discontinued product so you are probably going to have to just lay all the parts out and guess. You could also look for assembly instructions for a similar BBQ made by Weber. They all follow a logical sequence.
I did find reviews, you could ask if anyone has the manual and when you ask a question, the question is sent to those who have reviewed already.
Jackeroo Flinders 4 Burner
Dec 28, 2015 | BBQ Guys Grilling
Char Broil Gas BBQ Knobs just spin, no propane coming out.
Just a wild guess but I think on a Char Broil you have to push in the knob and turn it to the setting.
Feb 24, 2013 | Grilling
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Aug 10, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Lost hose assembly (parts 17,18,19) of my Firelight II propane BBQ Ducane 7011013 WH-008583
You can purchase the parts you need from the Ducane Parts Center 877.731.8081. Make sure you have your Model Number handy when you call. If they can't help you go to the following link
http://grillpartssearch.com/mm/merchant.mvc?Screen=CTGY&Store_Code=Gas_Grill_Parts&Category_Code=Plumbing
Good luck & Happy Grilling!!
May 18, 2011 | Ducane F7011013
Need a manual for a Jumbuck Endeavour 4 MKII BBQ.
Need assembly instructions for a Voyager 4 Jumbuck BBQ, no more than two years old. Our daughter recently moved, the BBQ was dismantled by the removalists and she is now unable to find the assembly manual.
Many thanks
Rod Gilbert - rod.gilbert@hotmail.com
Apr 20, 2010 | Grilling
No assembly instructions to build the bbq
Go here to get manual.
http://www.ducane.com/manuals/
Good Luck and Please Rate FixYa!
Mar 21, 2009 | Ducane Affinity 3100
Chain
It is used to maually light the burner with a match. The match goes in the "loop" part. It is attached so that it isn't lost/
May 12, 2007 | George Foreman GP324 Stainless Steel Grill
Baby Gear Logo
37 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
