Question about Riso RP 3700
Riso RP 3700 T12-305 - Riso RP 3700
    New Friend:
  • 58 Answers
T12-305 The master compression sensor does not go ON within 6.5 s after the master compression motor operates in the return direction.
kindly try to check your master roll and respool it. the problem could also be because your master cannot be dispose the old master properly. remove the old master and respool your master roll and initiate your machine or turn it of and turn it on again. hope to be of help.
Posted on Feb 14, 2014
  • 55 Answers
SOURCE: on riso pr 3700 can not get the full image on
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Posted on May 01, 2011
  • 22 Answers
SOURCE: master wont ink up on riso 3700, How do I check ink pump and test
This is unlikely that the pump is not working.. I have 2 RP 3700s.. The screens are probably clogged.. with old ink.. or there could be a fit problem with the ink tube to the drum.. (no vacuum). With the drum in the machine and the ink in installed.. Take handle of a hammer and lightly (LIGHTLY!) push to ensure that there is no air pocket in the ink tube.. Carefull not to push too hard and squirt ink all over inside the machine. Also ink screens can be taken off and cleaned with varsol and re-installed.. Also as a final check.. make sure you are makeing a master.. look closely to see if you have a lazer burned image on your master.
Posted on Aug 11, 2009
SOURCE: I have a Riso RP 3700 and I changed a drum from
I've read a little about flushing drums with solvent or even gasoline or diesel google it a little see how people have done it. though I can imagine a Switch from a dark to light colour might be impossible. You could pull the screen off and wash it out. Some ideas. No solutions.
Posted on Mar 23, 2011
  • 55 Answers
SOURCE: i have a problem withz riso rp 3105 ep
Many people have an problem. Some people have a solution.
To provide a solution you have to describe your problem!(Simple, but the hard truth. Must I be sorry for the clear words?)
Posted on Oct 04, 2012
arka_kt_tatk
  • 14 Answers
SOURCE: My riso Rp 350
your drum may be clean ...sensor and ink .....you also clean old ink
Posted on Aug 06, 2013
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
How to change riso roller
look for a service manual for your machine. with my rn2255aw.. it was just a removal of one screw/bolt then i have removed my pressure roller and cleaned it with soap and cloth.. removed the old dried inks caused by misfeeds. then let it dry and put a drop or 2 drops of oil on the bearings then reinstall them. hope to be of help.
May 31, 2013 | Riso RP 3700
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
Riso rp error t98-526
526 Drum set safety switch is ON, but drum connection signal is OFF.
try to remove the drum and re-install it. hope to be of help
Feb 25, 2013 | Riso RP 3700
System error T01-521
mon riso RP 3100 ep donne le code to1-521. veuillez me trouver une solution merci
Nov 22, 2012 | Riso RP 3700
T98-526
riso rp error T98-526
Oct 31, 2012 | Riso RP 3700
I have a problem withz riso rp 3105 ep
Sep 18, 2012 | Riso RP 3700
I need a driver for Riso RP 3700 and I can't find the site where I could get a free version since I lost the disk and the peripherals included in the sale.
Try this link and get back to me.
http://mydownloadhq.com/your-file.asp?PID=3cb89198-4f31-4c33-b686-576ae7cc197c&q=service+manual+riso+rp+3700+megaupload
Jan 03, 2011 | Computers & Internet
On riso pr 3700 can not get the full image on landscape mode when I make a master
Mar 31, 2010 | Riso RZ390 Duplicator
Riso RP 3700 Logo
460 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
