Question about Garden
Drive chain slack how do you tension
What tools are needed
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
What kind of mower ???
Posted on Dec 28, 2013
How do i adjust the chain on my yz 426f
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2006 YZ450F Chain Tension YZ 400 426 450
Yamaha YZ450F Chain slack adjusting
Yamaha YZ426F Owner Service Manual
OEM parts for Yamaha
Yamaha YZ450F Owner Manual Page 3
May 11, 2014 | 2001 Yamaha YZ 426 F
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
Ratcheting noise on startup
Yes the tensioner is what keeps pressure on the chain or belt to keep it tight.If the chain or belt gets too much slack it could jump a tooth or two or worse it could come off while you are driving,causing severe engine damage.
May 07, 2012 | 2006 Hyundai Sonata
I would like to have a diagram of the timing comfiguration of a 2002 dodge intrepid 2.7 .....i am very interested in the timining marks for the camshafts
Hi, this engine uses plated links in the chain to match marks on the gears. See figure and installation procedure below. Let me know if you have any questions and thanks for using FixYa.
    1. Install the timing chain by performing the following procedure:
    1. Verify that the crankshaft sprocket timing mark is aligned with the mark on the oil pump housing.
    2. Place the left side primary timing chain sprocket onto the chain, while aligning the timing mark on the sprocket to the 2 plated links on the chain.
    3. Lower the chain with the left sprocket through the left cylinder head opening.
    4. Loosely position the left camshaft sprocket over the camshaft hub.
    5. Align the plated link to the crankshaft sprocket timing mark.
    6. Position the timing chain around the water pump drive sprocket.
    7. Align the right camshaft sprocket timing mark to the plated link on the timing chain and loosely position the sprocket over the camshaft hub.
    8. Verify that all the plated links are aligned to their proper timing marks.
    1. Install the left lower timing chain guide and tensioner. Torque the bolts to 21 ft. lbs. (28 Nm).
      NOTE Inspect the timing chain guide access plug O-rings before installing. Replace damaged O-rings as necessary.
    2. Install the timing chain guide access plug to the left cylinder head and torque to 15 ft. lbs. (20 Nm).
      NOTE To reset the timing chain tensioner, oil will first need to be purged from the tensioner.
    1. Purge oil from the timing chain tensioner using the following procedure:
    1. Remove the tensioner from the tensioner housing.
    2. Place the check ball end of the tensioner into the shallow end of the Tensioner Resetting Special tool 8186.
    3. Using hand pressure, slowly depress the tensioner until oil is purged from the cylinder.
    4. Reinstall the tensioner into the tensioner housing.
    1. Reset the timing chain tensioner using the following procedure:
    1. Position the cylinder plunger into the deeper side of the Tensioner Resetting special tool 8186. Apply a downward force until the tensioner is reset.
    WARNING
    Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    1. Install the chain tensioner into the right cylinder head.
    2. At the right cylinder head, insert a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    3. Turn the left camshaft by inserting a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    4. If necessary, rotate the engine slightly clockwise to remove any slack in the timing chain.
    5. To arm the timing chain tensioner: Use a flat-bladed prytool to gently pry the tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner extends.
    6. Inspect and replace the timing chain cover gasket and oil seal.
    7. Apply a 1 / 8 in. (3mm) bead of sealer at the parting line of the oil pan and engine block.
      NOTE When installing the timing cover, guide the seal over the crankshaft to prevent damage to the seal-s lip.
    Install or connect the following:
    Timing cover and gasket and torque the M10 bolts to 40 ft. lbs. (54 Nm) and the M6 bolts to 105 inch lbs. (12 Nm)
    Accessory drive belt tensioner pulley
    Power steering pump
    Crankshaft damper
    Crankshaft center bolt and torque the bolt to 125 ft. lbs. (170 Nm) using tool 8191
    Accessory drive belts
    Fan module and electrical wiring harness
    Upper radiator crossmember
    Negative battery cable
    Dec 25, 2010 | Dodge Intrepid Cars & Trucks
    I just had my water pump changed and when everything was all finished I was told to start my car. Well it started right up but it sounded like the chain was dragging on metal. I opened the front plate and...
    here is the procedure for the tensioner:
    2. Apply a downward force until the tensioner is reset.
      WARNING Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    Oct 04, 2010 | 2002 Dodge Intrepid
    I need to know how to set thte timing chain
    Discoverd this indepth expalaination of process steps involved in the installation of the timing chain from an ASE certified technician. I hope this helps. See the repair manual on the link below.<br /> <br /> Link: <a href="http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html">http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html</a><br /> <table id="table14" style="BORDER-RIGHT: #000000 1px dashed; BORDER-TOP: #000000 1px dashed; BORDER-LEFT: #000000 1px dashed; BORDER-BOTTOM: #000000 1px dashed" bordercolordark="#000000" width="100%" bordercolorlight="#000000" border="0"> <tbody> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"><span class="name" roundtrip="0" lastvisited="3">By <a name="755408"></a><b roundtrip="0" lastvisited="0">Dave H</b>,<b> </b></span><span class="postdetails" roundtrip="0" lastvisited="0">Certified ASE Technician</span></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="100%" roundtrip="0" lastvisited="6"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-LEFT-WIDTH: 1px; BORDER-BOTTOM-WIDTH: 1px; BORDER-RIGHT-WIDTH: 1px"> </td> </tr> <tr> <td colspan="2"> <span class="postbody" roundtrip="0" lastvisited="77">PRIMARY TIMING CHAINS (NON-SUPERCHARGED) <br />NOTE:The 4.0L V8 has no engine timing alignment marks on the crankshaft or camshafts. Engine timing is achieved by installing the Crankshaft Setting Peg (303-531) and Camshaft Locking Tool (303-530). With the crankshaft setting peg in position, ensure the timing flat on each camshaft is in the uppermost position before installing camshaft locking tool. Variable camshaft timing unit may also be referred to as Variable Valve Timing (VVT) unit. <br /><br />NOTE:Special Tools Required: Crankshaft Setting Peg (303-531), Camshaft Locking Tool (303-530), Chain Tensioning Tool (303-532), Primary Chain Wedge (303-533) and Variable Camshaft Timing Oil Control Unit Setting Tool (303-654). See Fig. 232-Fig. 236 . <br /><br />NOTE:"A" bank refers to the right/passenger side of the vehicle and "B" bank refers to left/driver side of the vehicle. <br /><br />NOTE:Each door glass automatically drops 12 mm when the door is opened or when the convertible top is raised or lowered. It is important that windows are lowered before battery is disconnected to allow doors to shut properly. <br /><br />Removal ("A" Bank) <br />Tips Click a link to view tip <br />Tech1Tip: special tool <br /><br /><br />Remove timing cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). <br />Remove the variable camshaft timing oil control solenoid. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove the variable camshaft timing oil control unit housing retaining bolts and remove the variable camshaft timing oil control unit housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove and discard the variable camshaft timing oil control unit housing "O" rings. <br />Raise and support vehicle. Remove the bolt which secures the Crankshaft Position (CKP) sensor to the flywheel housing. Remove the CKP sensor and allow it to hang free under the engine. Remove the torque converter bolts access grommet from the flywheel housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Install the crankshaft damper bolt (old one) to the crankshaft, hand-tight only. Rotate crankshaft until the triangular arrow indent on the flywheel is visible through the access hole. See Fig. 144. Confirm that the timing flat on each camshaft is uppermost position. <br />Position the crankshaft so that the Crankshaft Setting Peg (303-531) engages fully into the timing slot. Install and tighten the bolt to secure the crankshaft setting peg. See Fig. 145. Remove the crankshaft damper bolt from the crankshaft and lower the vehicle. <br />Install the Camshaft Locking Tool (303-530) to the "A" bank camshafts, aligning the shafts slightly as necessary. Loosen the bolt that secures the exhaust camshaft sprocket and the bolt that secures the variable camshaft timing oil control unit. See Fig. 146. Remove camshaft locking tool. <br />Remove the primary chain tensioner bolts, primary chain tensioner and tensioner backing plate. See Fig. 147. <br />Remove the primary timing chain tensioner pivot bolt and remove the primary timing chain tensioner blade. See Fig. 148. <br />Remove the bolt which secures the primary timing chain guide. Noting the position of the primary timing chain guide, remove the primary timing chain guide from the upper retaining pin. See Fig. 149. <br />Remove the primary timing chain from the variable camshaft timing oil control unit and from the crankshaft sprocket. Clean and inspect all components. <br />Installation <br />If "B" bank timing chain was removed, see INSTALLATION. If not, go to next step. <br />If previously removed, install the timing chain sprocket to the crankshaft. The teeth of the "A" bank and the "B" bank timing chain sprockets on the crankshaft must be out of phase with each other. If they are in phase after installing, remove the sprocket, turn it on its vertical axis and reinstall sprocket. See Fig. 150. <br />Install the chain tensioning tool to the exhaust camshaft sprocket. Reposition the sprocket (and the variable camshaft timing oil control unit) for the most advantageous position for use of the tool. See Fig. 151. Remove the tool. <br />Install the primary timing chain into position over the crankshaft sprocket and the variable camshaft timing oil control unit. There must be no slack on the drive side of the primary timing chain and the sprockets must not be rotated on the camshafts, or the tensioning tool may not fit. See Fig. 152. <br />Install the primary timing chain tensioner blade to the cylinder block. See Fig. 148. Install the pivot bolt and tighten specification. See TORQUE SPECIFICATIONS. <br />Push the primary timing chain tensioner piston into the tensioner body to provide clearance for installing the primary timing chain. Insert a thin rigid wire through the hole in the end of the tensioner piston to displace the ball from the non-return valve seat. See Fig. 153. With the wire in position, press the piston fully into the tensioner body. Remove the wire. <br />Install the 2 primary timing chain tensioner bolts to the primary timing chain tensioner and locate the tensioner backing-plate on to the 2 bolts. Align and install the primary timing chain tensioner to the cylinder block and to the mating slot on the rear face of the primary timing chain tensioner blade. See Fig. 147. Tighten the primary timing chain tensioner bolts to specification. See TORQUE SPECIFICATIONS. <br />Use a Primary Chain Wedge (303-533), or 2 if needed, between the primary timing chain tensioner and primary timing chain tensioner blade, to take up the slack in the chain for tightening of the variable camshaft timing control unit and exhaust camshaft sprocket. See Fig. 154. <br />Using the chain tensioning tool, apply force to the tool in an counterclockwise direction to tension the chain on its drive side. See Fig. 151. While applying opposing force to the sprocket and chain, tighten the exhaust camshaft sprocket bolt to specification. See TORQUE SPECIFICATIONS. <br />Using the Variable Camshaft Timing Oil Control Unit Setting Tool (303-654), rotate the variable camshaft timing oil control unit fully counterclockwise to the fully retarded position. See Fig. 155. <br />Check that the primary chain wedges are still in place. While applying opposing force to the sprocket and chain using the chain tensioning tool, tighten the variable camshaft timing oil control unit bolt to specification. See TORQUE SPECIFICATIONS. Remove the chain tensioning tool and the primary chain wedges and camshaft locking tool. <br />Raise and support vehicle. Remove crankshaft setting peg. Install the CKP sensor and bolt to the flywheel housing. See Fig. 143. Tighten the CKP sensor bolt to specification. See TORQUE SPECIFICATIONS. Install the access grommet to the housing and lower the vehicle. <br />WARNING:Check that the ring dowels are engaged squarely. Fully locate the assembly as much as possible by hand. Failure to follow this procedure may result in damage to the vehicle. <br /><br />Install NEW "O" rings to the variable camshaft timing oil control unit housing. Lubricate the "O" rings and the bushing. Install the variable camshaft timing oil control unit housing. See Fig. 142. Install the variable camshaft timing oil control unit housing bolts. Tighten to specification. See TORQUE SPECIFICATIONS. <br />Install the variable camshaft timing oil control solenoid. See Fig. 141. Install and tighten the variable camshaft timing oil control solenoid bolt to specification. See TORQUE SPECIFICATIONS. <br />Install the timing chain cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). </span><br /></td></tr></tbody></table>
    Aug 26, 2010 | 2001 Jaguar XJ8
    How do I reattach chain after it slipped off
    Normal 0 This will be the basic instruction for most common saws. Check that the chain brake is in disengaged position by moving the front hand guard towards the front handle if the saw is equipped with a chain brake on the handle. Loosen the bar nuts on the clutch cover. Loosen tension screw or other adjuster (thumbscrew) to allow the bar to be moved toward the engine. Some saws have this tension adjustment built into the bar. This will provide enough slack in the chain to able to reinstall it. It may be necessary to remove the side cover to gain access to the clutch/gear assembly on the side of the engine if the chain also jumped the gear here. Remove the cover, inspect for any debris or other obstructions in this area. If none, replace the chain back over the drive gear and in the bar groove all the way around the bar. It may be necessary to turn the bar adjuster screw more to provide enough slack in the chain to do this. Once the chain is in place reinstall the cover and bar lock nuts. Snug up the nuts but do not tighten these. Turn the bar/chain adjuster screw to tighten the chain on the bar (take up slack). I usually tighten to a point where there is no slack between the chain and the bottom of the bar and I can still turn the chain easily around the bar by hand. With experience you will get the feel for this chain tension. Once the chain is properly tensioned, tighten the bar lock bolts/ nuts on the side cover. I hope this helps you out.
    Jun 25, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Chain will not move on chainsaw
    Some Poulan Pros have an adjuster screw on the front of the engine case right beside the bar, some have a tool less adjuster on the clutch cover, and some have a slot in the bar for adjusting the chain tension.
    May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    1997 nissan maxima with 3000 24 valve twin cam v6. I am need a water pump.What comes off to change.
    Hello and thank you for using FixYa!
    To replace the water pump, you will need to remove all the drive belts. Then there are 2 black covers on the front timing cover. One cover is for the chain tensioner, the other is for access to the water pump. I would recommend you replace the tensioner the same time you do the water pump. The reason is, you need to remove that tensioner so the chain has slack. When the chain has slack, you can then unbolt and pull the water pump out. It could get stuck, so there are bolts that you need that you would use to run in to pop the pump free.
    Hope this helps , Thanks Jay!
    Jul 17, 2009 | 1997 Nissan Maxima
    I have a 99 dodge intrepid that threw a rod and my father-in-law and I have been trying to time the car for a year now. We get number one piston up but the mark on the oil pump doesnt line up with the mark...
    I'm not sure what you may be "doing wrong", but here is the manufacturer procedure for aligning the timing marks.
    ^Refer to this diagram during step 12.
    ^Refer to this diagram during step 13.
    ^Refer to this diagram for step 19.
    1. Align crankshaft sprocket timing mark to the mark on oil pump housing. NOTE: Lubricate timing chain and guides with engine oil before installation.
    2. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links.
    3. Lower the primary chain with left side sprocket through the left cylinder head opening. NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
    4. Loosely position left side camshaft sprocket over camshaft hub.
    5. Align timing (plated) link to the crankshaft sprocket timing mark.
    6. Position primary chain onto water pump drive sprocket.
    7. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain and loosely position over camshaft hub.
    8. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
    9. Install left side lower chain guide and tensioner arm. Tighten attaching bolts to 28 Nm (250 in. lbs.). NOTE: Inspect oil ring on chain guide access plug before installing. Replace O-ring as necessary.
    10. Install chain guide access plug to left side cylinder head. Tighten plug to 20 Nm (15 ft. lbs.)
    11. NOTE:
    To reset the primary timing chain tensioner, engine oil will first need to be purged from the tensioner.
    12. Purge oil from timing chain tensioner using the following procedure:
    a) Place the check ball end of tensioner into the shallow end of Special Tool 8186.
    b) Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
    13. Reset timing chain tensioner using the following procedure:
    a) Position cylinder plunger into the deeper end of Special Tool 8186.
    b) Apply a downward force until tensioner is reset. NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball. CAUTION: Ensure the tensioner is properly reset. The tensioner body must bottom against the top edge of Special Tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    14. Install the reset chain tensioner into the right cylinder head.
    15. Position tensioner retaining plate and tighten bolts to 12 Nm (105 in. lbs.).
    16. Starting at the right cylinder bank, insert a 3/8" square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 in. lbs.).
    17. Turn the left side camshaft by inserting a 3/8" square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 in. lbs.).
    18. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
    19. To arm the timing chain tensioner: Use a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner is armed (extends).
    20. Install the timing chain cover, crankshaft damper, and cylinder head covers.
    21. Install camshaft position sensor and connect electrical connector.
    Hope this helps!
    Mitchell
    May 16, 2009 | 1999 Dodge Intrepid
    Garden Logo
    52 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
