Question about HP EliteBook 8530p Notebook
Will not start
Will start when connected to docking station using power button. Will not start using power button on HP notebook.
  • 335 Answers
It sounds like the DC charging port on the laptop may be damaged, or it may be the power cord...here's how to tell:
First thing....remove the laptop battery, click the battery back onto the laptop and try again. If this doesn't help then read on...
When you put the laptop on the dock, it is getting it's power from the dock connector on the bottom of the laptop. When it is not on the dock, it gets power from your DC adapter. Soooo......take the laptop off the dock and plug the DC adapter into the laptop. Do you see ANY led's light up (on the laptop) when you plug the power cord directly into the laptop? If not, then your DC power adapter for the laptop is probably dead. If you DO see any led's light up when you plug the power cord directly into the laptop but the power button won't turn the laptop on, then the power button on the laptop is the problem.
Take your laptop to an electronics store, and see if they have any universal power adapters for laptops (they come with tips to fit all major laptop brands). Test your laptop at the store with their new power adapter. If this fixes it, then buy the adapter. If this does not fix it, then you should take it to a reputable service shop to get the power button repaired or replaced......or call HP if your laptop is still in warranty.
Hope this helps!
Joe
Posted on Dec 27, 2013
Geekman
  • 32281 Answers
SOURCE: dock station for hp pavilion
You need to check the plug that plugs into the laptop to determine that you don't have a faulty lead or plug. Test it with a multimeter and wriggle the plug to see if the voltage reading remains steady. If it doesn't then it could be the lead and this is easily repaired.
You may be able to borrow an adapter to test your laptop's connector.
If you determine the fault is with the laptop then problem is most likely the connector socket on the laptop, it most likely need re-soldering onto the motherboard, or needs to be replaced. This requires the laptop to be dismantled completely.
A docking station would solve your problem because the docking station has its own power connector and you plug the existing power adapter into the docking station.
My HP is connected to a docking station, the other advantage is that the docking station has several more ports than the laptop which is useful.
Posted on Feb 12, 2009
shahabdun
  • 249 Answers
SOURCE: HP6715b hangs on start-up when docked
Try without connecting any devices.
Try to disconnect the dock.
Try to boot in safe mode.
Posted on Sep 11, 2009
proton77
  • 1183 Answers
SOURCE: Hi, i have a hp
Remove the battery from the portable and disconnect the Ac adapter. Press and Hold down the power button for 15 seconds.
Reconnect the Ac adapter only and power on the system. If the system is doing the same . The motherboard on the computer has gone bad.
You can read more on the same on the link below
HP support forum
Thanks for using Fixya
Proton
Posted on Oct 04, 2010
SOURCE: HP Elitebook 8540p is getting no video in docking station
The solution that resolved this problem On Bios version F.0E was:
  • Power up the unit off the docking station and plug it into the docking station.
  • Delete all copies of the COM1 port in the device manager.
  • Perform a restart on the docking station.
  • When you log back into windows go back into the device manager and redetect hardware.(You should now have 2 visable copies of the COM1 port. One will have a bang next to it.)
  • Delete both copies of COM1 and scan for hardware changes. (This should give you 1 good copy of the COM1.)
  • Power down the laptop, and take off the docking station.
  • Power it back up straight from the docking station and you will notice no more hangs when booting off the docking station
Enjoy...
Posted on Feb 10, 2011
bronk50
  • 27725 Answers
SOURCE: hp 2510p not charging
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Posted on Oct 09, 2012
Hy... I have an HP Pavilion dv7-2155eg and the notebook expansion base HP xb3000! - But my base doesn't light up the power display and sound display at the bottom. The power button works; but the...
you left out 2 facts when DID it last work ok on this LT.
never, last year , 2008 or what, my guess NEVER !
no OS stated, W7? what? and MUST MATCH !!! drivers !!!
facts the product is 100% dead now at HP, no support at all . period
they will just quip "legacy" sorry..
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=xb3000
you have the wrong dock.
here is the old data sheet it tell you only these PC work
The
xb3000
Notebook
Expansion
Base
is compatible
with
all
HP
Pavilion
dv2000,
dv6000,
dx6000,
dv9000,
tx1000,
tx2000
and Compaq Presario
V3000
and
V6000
series
notebooks.
this is what you have.
http://h10032.www1.hp.com/ctg/Manual/c01686692.pdf
shows xp last supported OS back then then.2008
but?
more lots more, you can search at HP all day but
NO OS STATED BY YOU
and why you think your PC runs on this X
the last post at HP said
HP 15-r264dx does not have docking port, you have to use USB "dock" such as HP USB 2.0 or USB 3.0 docking stations.
and last here is your correct docking station (you never asked first)
https://h10057.www1.hp.com/ecomcat/hpcatalog/specs/provisioner/05/KN745AA.htm
KN745AA - HP Notebook QuickDock
so let me guess the real story
i found this docking station at a garage sale for $5
what does it FIT
answer, see link 2 above , PDF for the data sheet,
ever like just google ?
here is 1 hit, found the service guide. 2006(11 years old)
http://h10032.www1.hp.com/ctg/Manual/c01103327.pdf
page 6 shows it dont work on your PC.
so that 2 books that said that.
if does not mention OS, but 2006 we know is XP , never run XP ever.
there are rumors of hacks that can make it work but only no details.
for sure it must be a hardware match.
then you need drivers to run it, but if your OS is not XP
finding them now is very very hard.
only google can find them and I see ZERO
Jul 15, 2017 | HP Computers & Internet
Hi, i have a hp nx7400, it wont start or charge battery. tried with different adapters and with a docking station. when i push on button it will blink 8 times without battery connected, with battery...
HP support forum
Proton
Oct 04, 2010 | HP Compaq nx7400 Notebook
Try this
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=au&prodTypeId=321957&prodSeriesId=4097214&swItem=ob-83668-1&prodNameId=4096169&swEnvOID=1093&swLang=13&taskId=135&mode=4&idx=4
Jun 23, 2010 | HP EliteBook 6930p Notebook PC
I connect my B130 to an external display using a vga cable. Both screens work. But I am unable to turn my laptop's screen off using Fn F8
the screen wont go off unless you use a docking station. Once you are docked, you can close the notebook lid and use the machine like a desktop: with all your cables hooked into the station itself.
Dec 12, 2009 | Dell Inspiron B130 Notebook
Sep 11, 2009 | HP Compaq 6715b Notebook PC
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
Power jack connection broken on HP Omnibook xe3
I bought a docking station (port replicator) off ebay, and it has worked great. I had a look at the motherboard, and the docking station uses a different connection for power than the damaged AC port. So in summary, yes a docking port should solve your problem.
If you can get a docking station for it you may be able to solve it that way.
Apr 15, 2009 | HP OmniBook XE3 Notebook
Dock station for hp pavilion
Feb 12, 2009 | HP Pavilion dv6000z Notebook
No internet when docked.. needs network controller
Assume the docking station is powered. I have seen funny behaviour with my docking station. Sure way for it all to work is, everything off, fit to docking station, turn on with power button on docking station. Ensure network cable plugged before this.
Sep 16, 2008 | Dell Latitude D600 Notebook
Setup to my laptop docking station
Docking station Most docking stations allow a user to connect their laptop computer to a docking station and get the added support of other peripherals such as other drives.
Good Luck, Please dont for get to Vote/Thank You.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
HP EliteBook 8530p Notebook Logo
172 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
