AC is not throwing cold air anymore?
Five years old AC of mine has stopped throwing cold air. Please suggest me, if there's anything I can do it myself or I have to call some professionals from air conditioning repair port saint lucie.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
The unit must've run out of gas.You need to get a proffessional to get it re-gased.And ask him to locate any gas leak along the copper pipes and connections.
Posted on Jan 05, 2014
4 Suggested Answers
  • 182 Answers
SOURCE: central air conditioner
check the filter also sounds like a low freon charge.
Posted on Aug 18, 2008
  • 86 Answers
SOURCE: Portable Air Conditioning unit no longer blows out cold air
Clean out the condenser fins with a vaccumn try this first. God Bless have a nice day.
Dickson
Posted on Jul 02, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: 4 Year old 120000 BTU AC does not blow cold air
clean any filter you can find, blow out all coils with air and if it does not improve, have the pressures checked.
Posted on Jun 12, 2010
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
Sep 13, 2012 | 1999 Ford Taurus
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
Model CKL36-IL was installed just before I purchased home in October 2005. How long is warranty? Recently had it repaired (was dirty). Repairman said it looked/sounded like compressor was about to go...
Factory parts warranty is five years all parts one year labor. Capacitor and/or fan motor has gone out and will need replaced. The breaker will throw itself off if the condition gets bad enough. Suggest not using until repaired, turn off breaker.
Jul 30, 2011 | Goodman CKL36AR36 Air Conditioner
My unit is 5 years old and will not power on. It is not the outlet or the cord, I fear it is the electronic board. Any suggestions to diagnose before i throw away?
Mine was the power supply. I was able to repair it though. Pleasd contact me before you throw it away. I need a touch screen. My daughter used it for a drum!! Kennykbe@hotmail.com
Jan 27, 2011 | Brookstone Pure-Ion (506840) Air Purifier
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
When turning on central air, our main electrical breaker is tripping. This is a brand new home barely over 1 year old. Should the AC have a warranty not covered by a builders contract??
Builders give a one year warranty but your air conditioner has five years on all parts. Anything outside the unit is not covered under the ac warranty. Breakers,stopped up drain and dirty coils.
Jun 09, 2009 | Weather King 10AJA6001AH Air Conditioner
Not getting cold anymore
Unit has probably lost its charge of refrigerant.
Check for warranty, or buy another one.
Usually they are not worth repairing, sorry
Jun 06, 2008 | LG Goldstar GWHD5000 wall/window Air...
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
